Siebel Hospitality Guide > Getting Started with Siebel Hospitality > Process of Setting Up Hospitality Workflows >
Verifying That Hospitality Workflows Are Active
Perform the following steps to verify that each Hospitality workflow process is active. This task is a step in Process of Setting Up Hospitality Workflows. To verify that Hospitality workflows are active
- Navigate to the Administration - Business Process screen, then the Workflow Processes view.
- In the Workflow Processes list, query for the Siebel Hospitality workflows using the following query string in the Name field:
*SHM* OR *TNT*
- Make sure that the value of the Status field in each workflow is Active.
