Siebel Hospitality Guide > Getting Started with Siebel Hospitality > Process of Setting Up Hospitality Workflows > Generating Database Triggers for Hospitality WorkflowsThe Generate Trigger (GenTrig) component on Oracle's Siebel Server allows you to generate database triggers. Workflow policies use database triggers to identify which records match policy conditions. For more information about database triggers, see the chapter about administering a workflow policy in Siebel Business Process Framework: Workflow Guide. To generate database triggers for the Hospitality workflows, follow this procedure. This task is a step in Process of Setting Up Hospitality Workflows. To generate database triggers for Hospitality workflows
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
