Siebel Hospitality Guide > Getting Started with Siebel Hospitality > Process of Setting Up Hospitality Workflows > Triggering the TNT SHM Quote Group Workflows with Workflow Monitor AgentThe Workflow Monitor Agent is a functionality that checks when the conditions of a workflow policy are met, and performs actions after those conditions are met. For more information about the Workflow Monitor Agent, see the chapter about administering a workflow policy in Siebel Business Process Framework: Workflow Guide. The TNT SHM Quote workflow group is a subset of Siebel Hospitality workflows. The workflows in TNT SHM Quote group require database triggers in order to run. This procedure sets up the Workflow Monitor Agent to run the workflows in the TNT SHM Quote workflow group using database triggers. The TNT SHM Quote workflow group includes the following workflows:
The TNT SHM Quote workflow group also encompasses a set of defined policies. Each policy has a condition and an action. Each action specifies a workflow to run. The action is triggered by the condition established in the policy. To use the Workflow Monitor Agent to trigger the Hospitality workflows in the TNT SHM Quote workflow group, follow this procedure. This task is a step in Process of Setting Up Hospitality Workflows. To trigger the TNT SHM Quote group workflows with Workflow Monitor Agent
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
