Siebel Hospitality Guide > Managing Property-Specific Menus and Packages > Process of Managing Menus and Packages >
Editing Function Menus, Packages, and Line Items
You can modify the details of menus, packages, and their child product items that are associated with functions.
This task is a step in Process of Associating Menus and Packages with Functions.
To edit a function menu or package and line items
  1. Display a list of functions associated with quotes or orders.
    For more information about functions associated with quotes or orders, see Displaying Quote and Order Functions.
  2. In the Function list, select the function in which to edit a menu or package.
  3. Click the Line Items subview tab.
  4. In the line items list, select the menu, package, or component product to edit.
  5. Change the values of the fields as required. Some fields are described in the table that follows.
    NOTE:  The behaviors and calculations of many fields are affected by the menu or package type. For more information about field calculations and behaviors in the various types of menus and packages, see Menu and Package Types Reference.
    Field
    Comments
    Item
    Shows an Explorer-type hierarchy. For a single item, displays a document icon. For a menu or package with child items, displays a folder icon. When you add a menu or package as a line item, the whole hierarchy is added and becomes visible.
    Available selection changes dynamically with the value in the Grouping field. If you try to edit or replace a child item within a menu or package, the Pick Line Item dialog box displays only the items with the same Grouping as the selected menu or package child item. However, if you click Show All Products, the Pick Line Item dialog box displays one of the following lists:
    • If the parent of the selected child item is a package, the Pick Line Item dialog box displays all the items associated with the current property irrespective of their Grouping values.
    • If the parent of the selected child item is a menu, the Pick Line Item dialog box displays all the menu items associated with current property, irrespective of their Grouping values.
    Product Type
    Read only. Type of menu or package. Determines the pricing method.
    • Menu Per Person. One menu for each person. The price can be a fixed price for each person, or a variable price for each person depending on the items selected.
    • Package Each. Fixed price for a quantity of 1 of the package, regardless of the number of people.
    • Package Item Price. Variable price for each person where individual item prices are broken out.
    • Package Per Person. Fixed price for each person where individual item prices are not broken out.
    Grouping
    Read only. Identifies related groups of products. Allows you to do searches for products classified by related groups. For example, Dinner could be a menu grouping, and this would help you to find all the dinner menus that are available in a property.
    Resource Type
    Read only. Possible values are as follows:
    • Critical. Item is necessary for an event to occur. The application tries to reserve this item when a quote is created.
    • General. Item is noncritical; that is, not necessary for an event to occur.
    • Non Critical. Item is noncritical; that is, not necessary for an event to occur.
    Qty
    How many products are included in this line item.
    Extended Quantity
    Displays the same value as Qty for parent and static child line items. Calculated for per person child line items. The calculation is parent quantity multiplied by child quantity.
    The default value of Extended Quantity for a Package Per Person or a Menu Per Person is generated by the value of Best Attendance. For example, when you add a menu per person to a function that has 50 expected attendees, the default value of Extended Quantity for the menu per person is 50. For more information about Best Attendance, see Best Attendance Field.
    Negotiated Price
    Price for this line item that has been negotiated with the customer, if different from the List Price. Can be a discounted price. The presence of both this field and the Discount Amount field allow you to specify both a discounted price and an amount for a discount, independently of each other, if required.
    Editable for line items that have prices, null and read only for fields that do not have prices. For example, in a Package Per Person, the child items are not priced but the parent package is priced. Therefore, in the child items, this field is read only, but in the parent package, this field editable.
    Discount Amount
    Amount of any discount that can apply to this product. You can specify a Discount Amount or a Discount %, but not both for the same item. If Discount Amount is specified, Discount % is null.
    The presence of both this field and the Negotiated Price field allow you to specify both a discounted price and an amount for a discount, independently of each other, if required.
    Discount %
    Percent of the discount to be applied to a line item price. You can specify a Discount % or a Discount Amount, but not both for the same item. If Discount % is specified, Discount Amount is null.
    Unit Net Price
    Calculated from the Negotiated Price or the List Price.
    If the Negotiated Price is null, the calculation is one of the following:
    • List Price minus (List Price multiplied by Discount %)
    • List Price minus Discount Amount
    If the Negotiated Price is not null, the calculation is one of the following:
    • Negotiated Price minus (Negotiated Price multiplied by Discount %)
    • Negotiated Price minus Discount Amount
    Extended Net Price
    Calculated. Displays the Unit Net Price multiplied by the Extended Quantity.
    Fixed
    Read only. If selected, you cannot add new items to, alter the structure of, or change the quantities of the menu or package.
    Per Person Allocation
    Amount of revenue per person to allocate to a related revenue subcategory. Read only and null for a Package Per Person, Package Each, or Package Item Price. For more information about allocations, see Revenue Allocations for Menus and Packages.
    Split Pricing
    Applies to menus only. If selected, indicates a split menu. If the Split Pricing check box of any child menu item is selected, the Split Pricing check box of the parent item is automatically selected. Read only at the parent menu level. Editable at the child item level.
    Service Charge Inclusive
    If selected, the service charge is included in the List Price. If cleared, the List Price does not include the service charge.
    Tax Inclusive
    If selected, tax is included in the List Price. If cleared, the List Price does not include tax.
    Substitutes
    Allows you to select from a list of products that can be substituted for the current product, if specified by the administrator. Selecting a substitute product in this field might update other fields in this line item with information from the substitute product record.
    Recommendation Message
    Read only. Message that you can use to influence a customer to buy the product. For example, if the product is an entree, this field might specify a wine that is compatible.
  6. To edit a child item in a menu or package, expand the folder icon in the Item field, and repeat Step 4 and Step 5.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
