Siebel Hospitality Guide > Setting Up Products and Assets >
Forecasting Product Consumption
For most products, the quantity to be used at an event is usually the quantity of the product line item. If a quantity is entered for a line item, then the line item value is used to calculate revenue. However, for some products, the quantity to be used at an event, which is used to forecast revenue, is calculated from the number of attendees.
For more information about how product consumption forecasting can be applied, see Example of Product Consumption Forecasting.
This task is a step in Roadmap for Setting Up Products and Assets.
To forecast product consumption
  1. Navigate to the Administration - Product screen, then the Products view.
  2. In the Products list, create a new product record.
  3. In the new record, complete the fields, as required.
    Some fields are described in the following table.
    Field
    Comments
    Forecast Qty
    Select to enable product consumption forecasting. Clear to use the line item quantity to forecast the revenue for the item, instead of product consumption forecasting.
    UoM
    The unit of measure by which the product is sold.
    Consumption UoM
    The unit of measure for actual consumption by the attendees. For example, coffee might be sold by the gallon for a function, but the attendees might consume coffee by the cup.
    UoM Conversion Factor
    The ratio of Consumption UoM to Product UoM. For example, if there were 20 cups of coffee in 1 gallon of coffee, then the ratio is 20 to 1, and the conversion factor is 20.
    Consumption Factor
    The expected per-person consumption of the product. For example, if each attendee is expected to consume two cups of coffee, then the Consumption Factor is 2.
    % Participation
    The percentage of attendees who are expected to consume the product, expressed as a fraction of 1. For example, if 80 percent of attendees are expected to consume the product, then enter 0.8 to this field.
    NOTE:  In some cases, the percentage participation might be different from property to property. For example, in colder states, people might drink hot coffee than in warmer states. In this case, it is necessary to create different products with different values in this field.
  4. Click Release to make the product take effect.
This topic gives one example of product consumption forecasting. You might use this feature differently, depending on your business model.
A customer requests coffee for an upcoming event at which 100 attendees are expected. You know from experience that approximately four out of five attendees drink an average of two cups of coffee at such an event. The price of coffee is 10.00 per gallon. From this information, the consumption quantity of the product can be forecast for this event. The amount of revenue expected from this product can also be estimated for this event.
Create a product representing the coffee in Siebel Hospitality, as shown in the procedure that follows.
To forecast product consumption for an event
  3. In the new record, complete the fields with the values shown in the following table.
    Field
    Value
    Comments
    Forecast Qty
    Selected
    Product consumption forecasting is enabled.
    UoM
    Gallon
    None
    Consumption UoM
    Cup
    None
    20
    Each coffee-sized cup holds approximately 6 ounces.
    Consumption Factor
    2
    Attendees who consume coffee are expected to consume two cups each, on average.
    % Participation
    0.8
    80 percent of attendees are expected to drink coffee.
    The forecasting calculations and results for the event are shown in the following table.
    Forecast
    Calculation
    Result
    Number of attendees consuming the product
    100 multiplied by 0.8
    80
    Number of cups consumed
    80 multiplied by 2
    160
    Number of gallons consumed
    160 divided by 20
    8
    Revenue
    8 multiplied by 10.00
    80.00
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
