Siebel Hospitality Guide > Managing Property-Specific Event Quotes > Reviewing Revenue Estimates for Quote Functions >
Reviewing Parent Revenue Category Revenue Estimates
Review the parent category revenue estimates from the Revenue Estimates view. Parent Category estimates take into account the revenue estimates for functions, their subfunctions, and child subfunctions. The topic details how to review function revenue estimates, and also details how these estimates are calculated for functions with subfunctions. Reviewing Function Revenue Estimates
When reviewing the revenue for function space rental, the values contained in the fields might reflect a number of different function spaces. This is because the revenue totals for all active function spaces are reflected in this view. If you switch from a function space to its backup space, more than one active space might exist. For more information about switching, see Switching a Function to the Backup Space. This task is a step in Reviewing Revenue Estimates for Quote Functions. To review function revenue estimates
- Navigate to the Quotes screen, then the List view.
- In the Quotes list, query for and select the quote.
- In the Quote record, click the link in the Name field.
- Click the Functions view tab, and select the function in the list.
- Scroll down, and click the Revenue Estimates view tab.
- In the Revenue Estimates list, review the information.
The following table describes some of the fields.
Parent Revenue Category/Revenue Category |
The parent revenue category and revenue category with which function space revenues are associated. |
Projected Revenue - Total |
Default value is the Average Value Total. The user can update the value after consulting with the customer during the quote process. |
Projected Revenue Per Person |
Displays the projected revenue for each attendee. The Projected Revenue Total is divided by the Set number of attendees. If the Set number is unknown, then the Projected Revenue Total is divided by the Guaranteed number of attendees. If the Guaranteed number is unknown, then it is divided by the Projected number of attendees. If the projected number is unknown, then it is divided by the expected number of attendees. |
Average Value Total |
Shows the average value for a given function type or business type on the date of the function by parent category. This value is set by the revenue managers as a guideline. |
Average Value Per Person |
Displays the average value for each attendee. The Average Value Total is divided by the Set number of attendees. If the Set number is unknown, then the total is divided by the Guaranteed number of attendees. If the Guaranteed number is unknown, then the total is divided by the Projected number of attendees. If the Projected number is unknown, then the total is divided by the Expected number of attendees. |
Line Item Expected Profit |
Displays the expected profit for the sum of the line items. Calculated by multiplying Total Line Item Revenue by the profit percentage of that particular Parent Revenue category. |
Total Line Item Revenue |
Sum of the revenue for the line items including functions and subfunctions. |
Total Line Item Revenue - Function |
Sum of the projected revenue for the selected function. |
Total Line Item Revenue - Sub Function |
Sum of the projected revenue for all subfunctions associated with the selected function. |
Per Person Line Item Revenue |
Displays the line item revenue for each attendee. Total Line Item Revenue divided by the Set number of attendees. If the Set number is unknown, then the revenue is divided by the Guaranteed number of attendees. If the Guaranteed number is unknown, then the revenue is divided by the Projected number of attendees. If the Projected number is unknown, then the revenue is divided by the Expected number of attendees. |
Projected Profit |
Displays the projected profit for the function. Calculated by multiplying the Projected Revenue Total by the profit percentage defined in the Property Pricing Admin screen, Profit Series view. |
Service Charge |
Displays the total service charges for the function. |
Tax |
Displays the total taxes for the function. |
Overriding the Average Values for Subfunction Categories
During the initial setup of the average values of a property, the revenue manager assigns average values to the various function types that exist at a property. The revenue manager uses past history to estimate the average revenue contributions associated with each function type. During the opportunity capture stage, the sales representative might not fill in all information about a function, and might decide to keep the function details at a very high level. As a result, only the details of the main functions might have been added to the event agenda, and not subfunction details. This means that when the sales representative decides to detail the function by adding subfunctions, the revenue contributions are added twice to the function. This is because some of the categories for the function can be added at both the function level initially and then at the subfunction level when the function is detailed. For example, a Meeting function can be added to an opportunity with an Audio Visual and Coffee Break revenue contribution. Later, the sales representative might decides to add the Coffee Break as a subfunction of the main function. In this case, the revenue contribution for the function has been added twice. In order to make sure that the revenue contribution is not mistakenly counted twice, an average value override for subfunctions has been put in place in Siebel Hospitality. This average value override is subject to a number of rules as follows:
- Rule 1: The subfunction category revenue estimate takes precedence over the estimate that exists at the parent function level.
- Rule 2: Multiple subfunction revenues of the same category are added together.
- Rule 3: The subfunction category revenue override facility overrides one function level higher than the level at which it exists.
The rules for function category average value overrides are illustrated in the following examples:
- Example 1: One main function that contains two subfunctions
- Example 2: One Main Function that Contains a Subfunction and a Child Subfunction of the Subfunction
Example of a Function with Two Subfunctions
Table 34 provides the details of the main function.
Table 34. Main Function Details
Function 1 |
Meeting |
Food |
(Not applicable) |
130 (Total revenue) |
Lunch |
100 |
Coffee Break |
30 |
Table 35 provides the details of the first subfunction.
Table 35. First Subfunction Details
Subfunction 1 |
Coffee |
Food |
(Not applicable) |
45 (Total revenue) |
Coffee Break |
45 |
If the user indents Subfunction 1 under Function 1, then Rule: 1 applies; The subfunction category revenue estimate takes precedence over the estimate that exists at the parent function level. Table 36 shows the changes to Function 1 when Subfunction 1 is indented.
Table 36. Main Function Details After Subfunction is Added
Function 1 |
Meeting |
Food |
(Not applicable) |
100 (Total revenue) |
Lunch |
100 |
Coffee Break |
0 |
The Coffee Break revenue is overridden and is set to 0 at the parent function level. This means that the revenue estimate that is displayed at the quote level would be as shown in Table 37.
Table 37. Revenue Details at the Quote Level
Food |
(Not applicable) |
145 (Total revenue) |
Lunch |
100 |
Coffee Break |
45 |
At this stage, the sales representative decides to add another subfunction to the parent function, Function 1. Table 38 shows the details of this subfunction.
Table 38. Second Subfunction Details
Subfunction 2 |
Meeting |
Food |
(Not applicable) |
25 (Total revenue) |
Coffee Break |
25 |
When this subfunction is added, Rule: 2 is applied; Multiple subfunction revenues of the same category are added together. This is shown in Table 39.
Table 39. Summation of First and Second Subfunctions
Subfunction 1 + 2 |
Meeting |
Food |
Coffee Break |
70 |
Subfunction 1 |
Meeting |
Food |
Coffee Break |
45 |
Subfunction 2 |
Meeting |
Food |
Coffee Break |
25 |
The revenue estimate that is now displayed at the quote level is shown in Table 40.
Table 40. Revenue Estimate at Quote Level
Food |
(Not applicable) |
170 (Total revenue) |
Lunch |
100 |
Coffee Break |
70 |
Example of a Function with a Subfunction and a Child Subfunction
Table 41 provides the details of the main function.
Table 41. Main Function Details
Function 1 |
Meeting |
Food |
(Not applicable) |
Lunch |
100 |
Coffee Break |
30 |
Table 42 provides the details of the subfunction.
Table 42. First Subfunction Details
Subfunction 1 |
Coffee |
Food |
(Not applicable) |
Coffee Break |
45 |
If the user indents Subfunction 1 under Function 1, then Rule: 1 applies; The subfunction category revenue estimate takes precedence over the estimate that exists at the parent function level. The revenue estimate that is displayed at the quote level would be as shown in Table 43.
Table 43. Revenue Details at the Quote Level
Food |
(Not applicable) |
Lunch |
100 |
Coffee Break |
45 |
The sales representative then decides to add a child subfunction to the existing function. The details of this child subfunction are shown in Table 44.
Table 44. Child Subfunction Details
Child Subfunction 1 |
Coffee |
Food |
(Not applicable) |
Coffee Break |
25 |
Table 45 shows the changes to the Subfunction 1 when Child Subfunction 1 is indented.
Table 45. Main Function Details After Subfunction is Added
Function 1 |
Meeting |
Food |
(Not applicable) |
0 (Total revenue) |
Coffee Break |
0 |
Rule 3 is the applied: The subfunction category revenue override facility overrides one function level higher than the level at which it exists. The revenue estimate that is displayed at the quote level would then be as shown in Table 46.
Table 46. Revenue Details at the Quote Level
Food |
(Not applicable) |
125 (Total revenue) |
Lunch |
100 |
Coffee Break |
25 |
