Siebel Hospitality Guide > Managing Property-Specific Event Quotes > Workflow for Copy Function Line Items Functionality >
TNT SHM Copy Line Items Workflow
This workflow copies a list of selected function line items to the destination functions (target functions). This workflow takes the Row IDs of the selected line items and the Row IDs of the target functions, separated by semicolons (;), as inputs. Figure 11 shows this workflow.
Figure 11. TNT SHM Copy Line Items Workflow
Workflow Description. This workflow performs the following actions:
  1. Prepare Source LI Search Spec. This step prepares the search specification for the selected line items.
  2. Prepare Function Search Spec. This step prepares the search specification for the destination or target functions.
  3. Query Functions. Queries the list of target functions into which the line items are to be copied. The search specification that was prepared in Step 2 is passed as input. The other inputs are the business component name (Function BC) and From First (a literal value). This step also loops through the list of records that were queried.
  4. Is Function Record Exist. After the list of target functions is queried, if any active rows are returned, this step continues the flow to Step 5. If no records are returned the workflow ends.
  5. Copy LI DTU. Calls the Data Map to copy the selected line items to the destination functions.
  6. Is NPP? If the selected list of line items belongs to a non-participating property (NPP), this step copies the line items to the target functions by skipping booking and pricing functionalities.
  7. Prepare Copied LI Search Spec. Prepares the search specification for the copied line items that calls the booking and pricing functionality.
  8. Book And Price Items. Calls the booking and pricing functionality for the copied line items.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
