Siebel Hospitality Guide > Managing Hospitality Reports > Process of Converting the Banquet Event Order Report to a 12-Hour Format > Uploading the Modified Banquet Event Order Report TemplateTo upload the TNT_BEO.rtf template file back into Siebel Hospitality after you have modified it, follow this procedure. This task is a step in Process of Converting the Banquet Event Order Report to a 12-Hour Format. To upload the modified Banquet Event Order Report template
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
