Siebel Hospitality Guide > Managing Hospitality Reports > Process of Converting the Banquet Event Order Report to a 12-Hour Format > Configuring the STHeader Calculated FieldSTHeader is a calculated text field in the Banquet Event Order Report. STHeader combines the Service Start Time, Function Type, and Function Space or Location field values from your Siebel application. In STHeader, by default, StartTimeRep is the Function Time field in 24-hour format (00:00 to 23:59). You can replace StartTimeRep with SSTimeCalc, which is the Function Time field in 12-hour format (00:00 AM to 11:59 PM). SSTimeCalc identifies pre-noon times as AM and post-noon times as PM in all languages. To replace the 24-hour time value display in STHeader with a 12-hour time display, follow this procedure. This task is a step in Process of Converting the Banquet Event Order Report to a 12-Hour Format. To configure the STHeader calculated field
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
