Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Function Space Diary >
TNT SHM Gantt AX Date Time Interval PopUp Business Component User Properties
This topic describes the following user properties for the TNT SHM Gantt AX Date Time Interval PopUp business component of the Function Space Diary:
Activation Field 1
This user property is used to specify the fields to be activated.
Value |
Go To |
Parent Object Type |
TNT SHM Gantt AX Date Time Interval PopUp VBC |
Usage |
This user property is used to specify the fields to be activated. |
Value |
Day/Hour |
TNT SHM Gantt AX Date Time Interval PopUp VBC TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC TNT SHM Inventory Gantt AX Date Time Interval PopUp VBC |
Usage |
This user property is used to specify the default time scale when the Function Space Diary is opened. |
Major Label Drilldown Name
This user property is used to specify the drill-down destination for the label of the major axis, for each time scale. Use this user property to specify whether drilldown is enabled or disabled in the major label for each of the time scales.
Value |
1;;2;Time Axis Item Drilldown;4;Time Axis Item Drilldown;8;Time Axis Item Drilldown;16;Time Axis Item Drilldown;32;64;;128;Time Axis Item Drilldown;256;Time Axis Item Drilldown |
TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC |
Value |
1;;2;Time Axis Item Drilldown;4;Time Axis Item Drilldown;8;Time Axis Item Drilldown;16;Time Axis Item Drilldown;32; |
Value |
Usage |
This user property specifies whether drilldown is enabled or disabled in the major label for each of the time scales. This user property is also used to specify the drill-down destination for the label of the major axis, for each time scale. |
Minor Label Drilldown Name
Use this user property to specify whether drilldown is enabled or disabled in the minor label for each of the time scales. This user property is also used to specify the drill-down destination for the label of the minor axis, for each time scale.
Value |
1;Time Axis Item Drilldown;2;;4;;8;;16;;32;Time Axis Item Drilldown;64;Time Axis Item Drilldown;128;;256; |
Value |
1;Time Axis Item Drilldown;2;;4;;8;;16;;32;Time Axis Item Drilldown |
Value |
Usage |
This user property specifies whether drilldown is enabled or disabled in the minor label for each of the time scales. This user property is also used to specify the drill-down destination for the label of the minor axis, for each time scale. |
Minor Default Day Part Duration
This user property is used to set the default duration in minutes for day parts on the minor axis.
Value |
0;660;900;1080 |
Usage |
This user property is used to set the default duration in minutes for day parts on the minor axis. The day parts are Morning, Lunch, Afternoon, and Evening. |
Minor Default Day Part Labels
This user property is used to specify the default day part labels.
Value |
Morning;Lunch;Afternoon;Evening |
Usage |
This user property is used to specify the default day part labels. |
Time Part BC Minor
This user property is used to specify the time scale for which the day parts are displayed. Use this user property to retrieve the time part details for a property in the Function Space Diary.
Value |
2;TNT SHM Property Day Part Pricing |
Value |
2;TNT SHM Day Part Display |
Value |
Usage |
This user property is used to specify the time scale for which the day parts are displayed. This user property retrieves the time part details for a property and indicates whether or not to display the time part details on the appropriate time scale in the Function Space Diary. For instance, the default value of TNT SHM Gantt AX Date Time Interval PopUp VBC is represented as follows: 2 is the LIC for the time scale in the Function Space Diary, and TNT SHM Property Day Part Pricing is the business component from which to get the time part details for a property. |
Time Part BC Minor 2
Value |
64;TNT SHM Day Part Display |
Usage |
This user property is used to specify the time scale for which the day parts are displayed. Usage of this user property is the same as Time Part BC Minor. |
TNT CMT CI Property Field Name
This user property is used to specify the field that displays whether the property is a SFA (Sales Force Automation) property or a CI (Consolidated Inventory) property.
Value |
TNT CMT SFA CI Condition |
TNT SHM Gantt AX Date Time Interval PopUp VBC Quote SHM Site |
Usage |
This user property is used to specify the field that displays whether the property is a SFA (Sales Force Automation) property or a CI (Consolidated Inventory) property. |
