Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Sleeping Room Mapping >
Business Component User Properties for Sleeping Room Mapping
This topic describes the following business component user properties:
Activation BC
This user property is used in C++ code to activate some of the fields of the SHM Site business component during the administration of sleeping room mapping.
Value |
TNT Product - ISS Admin |
Parent Object Type |
SHM Site business component |
Usage |
The value of this user property is a business component name. This user property is used in C++ code to activate some of the fields in the SHM Site business component during the administration of sleeping room mapping. |
Activation Field 1
This user property is used in C++ code to activate a defined field of the SHM Site business component, which is configured in the Activation BC user property during the administration of sleeping room mapping.
Value |
TNT Capacity |
Usage |
Activation Field 2
Value |
Description |
Usage |
Activation Field 3
Value |
TNT CRS Code |
Usage |
Child BC
This user property is accessed in C++ code to specify the virtual child business component to be run at a specific view aspect that is set at the applet using the business component.
Value |
TNT Mapped Specific Room |
Usage |
TNT SHM Arrival Date Field
Use this user property to set the correct value of the Calculated Arrival Date field on a change of duration (that is, a change to the value of the Num Nights Duration field) or a change to the closed date (that is, a change to the value of the Hospitality Close Date field).
Value |
Calculated Arrival Date |
Opportunity Home Add Virtual business component |
Usage |
The value of this user property is a business component field. When the Num Nights Duration field or the Hospitality Close Date field is updated, a new value for the Calculated Arrival Date field is calculated and set by way of C++ code. |
TNT SHM Departure Date Field
Use this user property to set the correct value of the Calculated Arrival Date field on a change of duration (that is, a change to the value of the Num Nights Duration field) or a change to the arrival date (that is, a change to the value of the Calculated Arrival Date field).
Value |
Hospitality Close Date |
Usage |
The value of this user property is a business component field. When the Num Nights Duration field or the Calculated Arrival Date field is updated, a new value for the Hospitality Close Date field is calculated and set by way of C++ code. |
TNT SHM Number of Nights Field
Use this user property to set the correct value of the Num Nights Duration field on a change of arrival date (that is, a change to the value of the Calculated Arrival Date field) or a change to the closed date (that is, a change to the value of the Hospitality Close Date field).
Value |
Num Nights Duration |
Usage |
The value of this user property is a business component field. When the Calculated Arrival Date field or the Hospitality Close Date field is updated, a new value for the Num Nights Duration field is calculated and set by way of C++ code. |
View Name
This user property is accessed in C++ code to enable the specialized behavior of the business component that is defined in the Child BC user property.
Value |
TNT Generic Room Type Mapping View |
TNT Mapped Specific Room business component |
Usage |
This user property is accessed in C++ code to enable the specialized behavior of the business component that is defined in the Child BC user property. |
