Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Menus and Packages >
Applet User Properties for Menus and Packages
This topic describes the following applet user properties:
BC Field Search LHS
Use this user property with the Parent BC Constraint Field user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet. The search specification is formed according to the sequence of the BC Field Search LHS xx and Parent BC Constraint Field xx user properties, where xx indicates 0,1,2,3,...
Value |
Vendor Id = |
Parent Object Type |
TNT Property Substitute Product Assoc Applet applet |
Usage |
Use this user property to format the search specification for the TNT Property Substitute Product Assoc Applet applet. This user property works with the Parent BC Constraint Field user property. This user property value acts as the LHS part of the search specification, and the value of the Parent BC Constraint Field user property acts as the RHS part of the search specification. |
BC Field Search LHS 1
Use this user property with the Parent BC Constraint Field 1 user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet. The search specification is formed according to the sequence of the BC Field Search LHS xx and Parent BC Constraint Field xx user properties, where xx indicates 0,1,2,3,...
Value |
Type = |
Usage |
Use this user property to format the search specification for the TNT Property Substitute Product Assoc Applet applet. This user property works with the Parent BC Constraint Field 1 user property. This user property value acts as the LHS part of the search specification, and the value of the Parent BC Constraint Field 1 user property acts as the RHS part of the search specification. |
BC Field Search LHS 2
Use this user property with the Parent BC Constraint Field 2 user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet. The search specification is formed according to the sequence of the BC Field Search LHS xx and Parent BC Constraint Field xx user properties, where xx indicates 0,1,2,3,...
Value |
Id <> |
Usage |
Use this user property to format the search specification for the TNT Property Substitute Product Assoc Applet applet. This user property works with the Parent BC Constraint Field 2 user property. This user property value acts as the LHS part of the search specification, and the value of the Parent BC Constraint Field 2 user property acts as the RHS part of the search specification. |
CanInvokeMethod: NavigateToView
Use this user property to enable or disable the NavigateToView method.
Value |
[Id] IS NOT NULL |
TNT SHM Function Line Items List Applet applet |
Usage |
Enables or disables the NavigateToView method. The value shows that when no records are displayed in the parent applet, the NavigateToView method is disabled. |
CanInvokeMethod: CopyRecord
Use this user property to disable the Copy Record functionality in Menu Administration, Event Order Item Administration, and Package & Specific Space Administration. The user property for the TNT SHM FSI Sleeping Room List Applet applet, which is enabled in the Oracle's Siebel CRM base application (the functionality that is common to Oracle's Siebel Business Applications that are not industry-specific), is disabled in Siebel Hospitality to resolve a visibility issue.
Value |
N |
TNT Property Product Admin List Applet, TNT Package Administration List Applet, TNT Menu Administration List Applet, and TNT SHM FSI Sleeping Room List Applet applets |
Usage |
Due to some technical constraints in Administration - Product, you must disable the Copy Record functionality in Menus and Packages-related administration views in order to release a copied product. |
Double Click Applet Method
Use this user property to specify the method to call on a double-click event.
Value |
AddProducts |
TNT Menu Product Pick Applet applet, TNT Package Product Pick Applet applet |
Usage |
When a user double-clicks one of the parent objects, the selected record is added to its originating or parent applet. The value of this user property is AddProducts, which is a custom method. If you do not use the double-click event, this user property can be deactivated. |
Effective Dates Constraint BC
Use this user property to constrain records in parent object applets by getting effective date details from the active business component. This user property exists in the Siebel CRM base application. In Siebel Hospitality, the value Internal Product - ISS Admin is replaced with TNT Product - ISS Admin for Menus and Packages to resolve a visibility issue.
Value |
TNT Product - ISS Admin |
TNT SHM FSI Function Space Assoc List Applet and TNT SHM FSI Indivisible Space Assoc List Applet applets |
Usage |
Constrains records in parent object applets by getting effective date details from the active business component. |
Enter Key Method
Use this user property to specify the Quick Add functionality that operates when a user clicks the Enter button.
Value |
Search |
TNT Attribute Search Applet applet |
Usage |
Specifies the Quick Add functionality that operates when a user clicks the Enter button. |
Mode
Use this user property to display the pop-up applet in edit mode.
Value |
Edit |
TNT Check Spelling control in TNT Menu Administration List Applet, TNT Package Administration List Applet and TNT Property Product Admin List Applet applets |
Usage |
Specifies that when a user clicks the Check Spelling button, the pop-up Applet is displayed in edit mode. |
Mode
Use this user property to display the pop-up applet in edit list mode.
Value |
Edit List |
AddItem control in TNT Menu Item List Applet, TNT Package Item List Applet applet |
Usage |
Specifies that when a user clicks the Add Items button, the pop-up applet is displayed in edit list mode. |
Named Method: CreateMenuPackages
Use this user property to call the Show Popup method when a user chooses the Create Custom Menu/Package applet menu item.
Value |
'INVOKE', 'ShowPopup', '"TNT Custom Menu/Package Popup Applet"', 'Edit' |
TNT SHM Function Line Items List Applet - Function, TNT SHM Function Line Items List Applet, TNT SHM Order Line Item List Applet applets |
Usage |
Calls the Show Popup method when a user chooses the Create Custom Menu/Package applet menu item. |
Named Method: NavigateToView
Use this user property to navigate to another view with search or sort specifications.
Value |
"INVOKESVC", "TNT SHM Workflow UI Service", "GotoView", "'View'", "'TNT SHM Category Line Items View'", "'Sort Spec'", "'TNT Grouping'", "'Search Spec'", "[TNT MM Search Spec]", "'Business Component'", "''", "'Row Id'", "''" |
Usage |
Navigates to another view with search or sort specifications. By default, the destination view is TNT SHM Category Line Items View, which is defined after the View parameter. |
Named Method: QuickAddItem
Use this user property to call the business service method when a user clicks the Quick Add button to add an entered item to the function line items.
Value |
"INVOKESVC", "TNT Utility Service", "QuickAdd" |
TNT Quote Catalog Quick Add Form Applet applet |
Usage |
Calls the business service method when a user clicks the Quick Add button to add an entered item to the function line items. |
Use this user property with the BC Field Search LHS user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet.
Value |
Vendor Id |
Usage |
See the usage of the BC Field Search LHS user property. |
Use this user property with the BC Field Search LHS 1 user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet.
Value |
Type |
Usage |
See the usage of the BC Field Search LHS 1 user property. |
Use this user property with the BC Field Search LHS 2 user property to form the search specification for the TNT Property Substitute Product Assoc Applet applet.
Value |
Id |
Usage |
See the usage of the BC Field Search LHS 2 user property. |
Popup
Use this user property to specify the pop-up Applet to be displayed when a user clicks the Check Spelling button.
Value |
Spell Checker Popup Applet |
Usage |
Specifies the pop-up Applet to be displayed when a user clicks the Check Spelling button. |
Popup
Use this user property to specify the popup applet that is displayed when a user clicks the Add Items button.
Value |
TNT Menu Product Pick Applet |
AddRecord control in TNT Menu Item List Applet applet |
Usage |
Specifies the popup applet that is displayed when a user clicks the Add Items button. |
Popup
Value |
TNT Package Product Pick Applet |
AddRecord control in TNT Package Item List Applet applet |
Usage |
Popup Dimension
Use this user property to specify the dimensions of the pop-up applet that is displayed when a user clicks the Check Spelling button.
Value |
400 X 550 |
Usage |
Specifies the dimensions of the pop-up applet that is displayed when a user clicks the Check Spelling button. |
Popup Dimension
Use this user property to specify the dimensions of the pop-up applet that is displayed when a user clicks the Add Items button.
Value |
500 X 600 |
AddRecord control in TNT Menu Item List Applet, TNT Package Item List Applet applets |
Usage |
Specifies the dimensions of the pop-up applet that is displayed when a user clicks the Add Items button. |
Product Search Fields
Use this user property to specify the Product fields in which a user can search using the Quick Add view.
Value |
Name, Product Type, TNT Display Name, TNT Unit of Measure, Part #, SHM Sub Category, Grouping Code, SHM Category, TNT Report Header, SHM Parent Category |
Usage |
Specifies the Product fields on which a search can be done in the Quick Add view. |
Search Spec Condition BC
Use this user property to constrain records in parent object applets by applying a formed search specification to the active business component. This user property exists in the Siebel CRM base application. In Siebel Hospitality, the value Internal Product - ISS Admin is replaced by TNT Product - ISS Admin for Menus And Packages to resolve a visibility issue.
Value |
TNT SHM FSI Function Space Assoc List Applet applet |
Usage |
Constrains records in parent object applets by applying a formed search specification to the active business component. |
