Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Event Checks >
Applet User Properties for Event Checks
This topic describes the following applet user properties:
CanInvokeMethod: ConfirmVoidEventCheck
Use this user property to enable the Void Event Check button for only event checks with a specified Status field.
Value |
[Status] = LookupValue('PS_SUBCONTRACTOR_STATUS', 'Posted') |
Parent Object Type |
SHM Invoice Form Applet and SHM Invoice List Applet applets |
Usage |
Enables the Void Event Check button for only event checks with a Status field of Posted. |
CanInvokeMethod: CopyRecord
Use this user property to disable the Copy Record functionality for records in the line items applet.
Value |
[TNT Disable New Delete Flag] AND [Id] IS NOT NULL |
TNT SHM Function Line Items List Applet, TNT SHM Order Line Item List Applet, TNT SHM Event Check Line Item List Applet, and TNT SHM Event Check Order Line Item Form Applet applets |
Usage |
Disables the Copy Record functionality when no records appear in the line items applet. |
CanInvokeMethod: DeleteRecord
Use this user property to disable the Delete Record functionality for records in the line items applet.
Value |
Usage |
Disables the Delete Record functionality when no records appear in the line items applet. |
CanInvokeMethod: PostCheck
Use this user property to disable the Post Check button for only event checks with the specified Status fields.
Value |
[Status] <> LookupValue('PS_SUBCONTRACTOR_STATUS', 'Voided') AND [Status] <> LookupValue('PS_SUBCONTRACTOR_STATUS', 'Posted') |
Usage |
Disables the Post Check button for only event checks with a Status field of Posted or Voided. Such event checks are read only. |
CanInvokeMethod: RecalculateInvoiceItemsAndTaxes
Use this user property to disable the Recalculate button for only event checks with the specified Status fields.
Value |
SHM Invoice Form Applet applet |
Usage |
Disables the Recalculate button for only event checks with a Status field of Posted or Voided. Such event checks are read only. |
CanInvokeMethod: ShowPopup
Use this user property to disable the Post Day button for only event checks with the specified Status fields.
Value |
Usage |
Disables the Post Day button for only event checks with a Status field of Posted or Voided. Such event checks are read only. |
CanInvokeMethod: VoidEventCheck
Use this user property to call the VoidEventCheck method for only event checks with a specified Status field.
Value |
Usage |
Calls the VoidEventCheck method for only event checks with a Status field of Posted. |
Disable Buscomp Hierarchy
Use this user property to disable the function hierarchy in the Functions List Applet of the Event Checks screen.
Value |
True |
TNT SHM Invoice Function List Applet applet |
Usage |
Disables the function hierarchy in the Functions List Applet of the Event Checks screen. |
OverridePopupVisibility
Use this user property to restrict the properties that appear in the dialog box that appears when users click the Open Day button and the Post Day button.
Value |
TNT Property Name, 5 |
SHM Check Date VBC Form Applet applet |
Usage |
Restricts the properties that appear in the dialog box that appears when users click the Open Day button and the Post Day button. |
View Aspect: SHM Invoice Detail View
Use this user property to set the event checks with the specified Status fields as read-only records.
Value |
TNT_EVENT_CHECK_STATUS |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the SHM Invoice Detail View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: SHM Invoice Detail View (Accounting)
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the SHM Invoice Detail View (Accounting) becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: SHM Invoice More Info View (Detail)
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the SHM Invoice More Info View (Detail) becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM All Across Organizations Invoice List View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM All Across Organizations Invoice List View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM All Invoices by Cluster View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM All Invoices by Cluster View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM All Invoices by Quote Property View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM All Invoices by Quote Property View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM Event Check Line Item Attribute View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM Event Check Line Item Attribute View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM Event Check Line Items More Info View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM Event Check Line Items More Info View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
View Aspect: TNT SHM Event Check Notes View
Value |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM Event Check Notes View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
