Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Pivot Applets >
Applet User Properties for Pivot Applets
This topic describes the following applet user properties:
BC Date Context Field
This user property is used to specify the pivot BC Date field name. This user property is activated when a user clicks the Go To Diary button.
Value |
Date |
Parent Object Type |
TNT SHM SR Inventory Display Dync List Applet - Read Only, TNT SHM SR Inventory Display Dync List Applet - Total Availability, TNT SHM SR Inventory Display Dync List applet, TNT SHM SR Total Avail Room Specific Dync List Applet, TNT SHM SR Total Transient Avail Dync List Applet |
Usage |
This user property contains the date field name in the pivot business component. This field keeps the date context with the parent business component. For example, if a user clicks the Next Set Column button in the pivot applet, the date column display advances to the next seven days. The same date context is maintained in the parent business component. |
Button Drilldown
This user property is used to specify the name of the drill-down object. This user property is activated when a user clicks the Go To Diary button.
Value |
Diary Drilldown |
Usage |
This user property is used to specify the name of the drill-down object that has been configured in the applet. |
CanModifyLayout
This user property is used to control the display of the Columns Displayed applet menu option.
Value |
N |
TNT SHM Property Projected / Blocked List Applet |
Usage |
If this user property is set to N, the Columns Displayed menu option is disabled. If this user property is set to Y, the Columns Displayed menu option is enabled. |
Parent BC Date Context Field
This user property is used to specify the parent business component date field name. This user property is activated when a user clicks the Go To Diary button.
Value |
Search Sleeping Room Date |
Usage |
This user property contains the parent business component date field name. This field keeps the date context with the pivot business component. For example, if a user clicks the Next Set Column button in the pivot applet, the date column display advances to the next seven days. The same date context is maintained in the parent business component. This field value is set with the same date in the pivot business component. |
Parent Src Field Default
This user property is used to specify the source field name in the source business component. This user property is activated when a user clicks the Go To Diary button.
Value |
Id |
Usage |
This user property contains the source field name in the parent business component. This field is used to query the child business component in the Destination view. |
Popup Applet Name
This user property specifies the name of the applet that is used to display records.
Value |
TNT SHM Property Special Dates / Sell Notes Popup Applet |
TNT SHM Function Space Inventory DyncPivot List Applet, TNT SHM Property Pricing - FS Full Day Discount Pivot Applet, TNT SHM Property Pricing - Function Space Pivot Applet, TNT SHM Property Pricing - Sleeping Room Government Pivot Applet, TNT SHM Property Pricing - Sleeping Room Pivot Applet |
Usage |
This user property is used to specify the pop-up applet name. This user property displays the records from the business component defined by the Popup BC Name user property. |
Popup BC Name
This user property specifies the name of the business component that displays the records in the applet specified by the Popup Applet Name user property.
Value |
TNT SHM Property Special Dates Action |
Usage |
This user property specifies the name of the business component that displays the records in the applet specified by the Popup Applet Name user property. |
Popup End Date Field
This user property is used to specify the end date field name.
Value |
End Date |
Usage |
This user property is used to specify the end date field name. This field is used to prepare the date range search specification on the business component specified by the Popup BC Name user property. |
Popup Start Date Field
This user property is used to specify the start date field name.
Value |
Start Date |
Usage |
This user property is used to specify the start date field name. This field is used to prepare the date range search specification on the business component specified by the Popup BC Name user property. |
Refresh Applet
This user property is used to refresh the applet.
Value |
Y |
TNT SHM SR Inventory Display Dync List applet |
Usage |
If this user property is set to Y, the applet is refreshed after records have been written to the applet. If this user property is set to N, the applet is not refreshed after records have been written to the applet. |
