Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Pivot Applets >
Virtual Business Component User Properties for Pivot Applets
This topic describes the following virtual business component user properties:
DCPivot Aggregation
This user property is used to aggregate the Total horizontally.
Value
N
Parent Object Type
TNT SHM Property Pricing - FS Full Day Discount Pivot VBC
The same user property is also available with different values in the following business components:
TNT SHM Property Pricing - Function Space Pivot VBC
TNT SHM Property Pricing - Sleeping Room Government Pivot VBC
TNT SHM Property Pricing - Sleeping Room Pivot VBC
TNT SHM Property Projected / Blocked
Usage
This user property is used to aggregate the Total values horizontally. This user property creates a row with the label Total and displays the total of all the attribute values in two separate rows.
DCPivot Attribute List 3
This user property is used to specify one of the attributes to be displayed in the pivot applet for all the dynamic columns.
Value
Maximum
Parent Object Type
Usage
DCPivot Attribute List 4
Value
Cost
Parent Object Type
Usage
DCPivot Attribute Read-Only List 0
This user property is used to specify a field in the pivot applet that is read only.
Value
Rental
Parent Object Type
Usage
DCPivot Attribute Read-Only List 1
Value
Threshold
Parent Object Type
Usage
DCPivot Data BusComp Link
This user property specifies the name of the link.
Value
SHM Site/TNT SHM Property Pricing - FS Full Day Discount
Parent Object Type
Usage
DCPivot DC Horizontal Totals
If the value of this user property is Y, a column named Total is created and displays the total of values for that record.
Value
N
Parent Object Type
Usage
DCPivot DC Vertical Totals
If the value of this user property is Y, a row labeled Total is created and displays the total of values for the attributes.
Value
N
Parent Object Type
Usage
DCPivot Group Key List 1
This user property is used to specify the grouping field.
Value
Day Part Name
Parent Object Type
Usage
DCPivot Group Key List 2
Value
Rooms
Parent Object Type
Usage
DCPivot Parent Search Field
This user property specifies the name of the parent business component field used for the search specification.
Value
Search Sleeping Room Date
Parent Object Type
Usage
Field Read Only Field: Authorization Level
This user property sets a specific field in a business component to be read only.
Value
Read Only - Authorization Level
Parent Object Type
TNT SHM FSI Auth Lvl
Usage
For more information about this user property, see the chapter on user properties in Siebel Developer's Reference.
Sum BC Name
This user property specifies the name of the business component that is used to add up the field values specified by user properties such as Sum Field 1, Sum Field 2, and so on.
Value
TNT SHM Quote Room Block Line Items Aggr
Parent Object Type
Usage
Sum Field 1
This user property specifies the name of the field for which to calculate a sum.
Value
Blocked;Blocked
Parent Object Type
Usage
This user property specifies the name of the field for which to calculate a sum. The first attribute is the field name in the business component specified by the Sum BC Name user property. The second attribute is the field name in the present business component.
Sum Field 2
Value
D/T1 Blocked;Blocked D/T1
Parent Object Type
Usage
Sum Field 3
Value
Picked Up;Picked Up
Parent Object Type
Usage
Sum Field 4
Value
Projected;Projected
Parent Object Type
Usage
Sum Field 5
Value
D/T1 Projected;Projected D/T1
Parent Object Type
Usage
Sum Key Field 1
This user property is used to uniquely identify the records in the business component specified by the Sum BC Name user property.
Value
Start Date
Parent Object Type
Usage
Sum Key Field 2
Value
Room Id
Parent Object Type
Usage
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
