Siebel Hospitality Guide > User Properties Reference for Siebel Hospitality > User Properties for Function Space Diary >
TNT SHM Compact Function Space Diary Applet User Properties
This topic describes the following user properties for the TNT SHM Compact Function Space Diary applet of the Function Space Diary:
Booking Drop Conflict Popup Default
If the pop-up applet name is not specified in the Booking Drop Conflict Popup Name user property, then this user property is used to specify the default selection option in the booking conflict pop-up window.
Value
Option
Parent Object Type
TNT SHM Function Space Diary
TNT SHM Function Space Diary Total Availability Applet
Usage
When a booking conflict occurs, a user can select either the OK, Option, Overbook, or Cancel option in the booking conflict pop-up window. If the pop-up applet name is not specified in the Booking Drop Conflict Popup Name user property, then this user property is used to specify the default option.
This user property is used to specify the applet name for the booking conflict pop-up window.
Value
TNT SHM Booking Option/Overbook Popup Applet
Parent Object Type
Usage
DateTime Popup Name
This user property is used to specify the applet used to query for function space bookings in an interval.
Value
TNT SHM Gantt Chart Query DateTime Interval Form Applet
Parent Object Type
TNT SHM Order Item Category Inventory Availability Gantt Chart Applet
TNT SHM Quote Item Category Inventory Availability Gantt Chart Applet
TNT SHM Order Item Inventory Availability Gantt Chart Applet
TNT SHM Quote Item Inventory Availability Gantt Chart Applet
TNT SHM Function Space Diary - Business Type
TNT SHM Function Space Diary - Meal Period
TNT SHM Function Space Diary - Function Type
TNT SHM Function Space Diary - Quote Name
TNT SHM Function Space Diary - Setup Style
Usage
Day Assignment Business Component
This user property is used to specify the business component that supports the function for assigning all the category bookings on a selected diary date to a specific space.
Value
TNT SHM Function Space Diary Assign Day VBC
Parent Object Type
Usage
Day Assignment Date Field Name
This user property is used to specify the field from which the day assignment date is retrieved.
Value
Date
Parent Object Type
Usage
Day Assignment Popup Applet
This user property is used to specify the pop-up applet to be used for day assignments.
Value
TNT SHM Function Space Diary Assign Day Popup Form Applet
Parent Object Type
Usage
This user property is used to specify the pop-up applet to be displayed when a booking conflict occurs.
Value
TNT SHM Option/Overbook Popup Applet
Parent Object Type
Usage
This user property is used to specify the pop-up applet to be displayed when a booking conflict occurs. This applet will display selection options such as Option, Overbook, and so on.
End Date
This user property is used to specify the field name from which the effective end date of the function is retrieved.
Value
End Date
Parent Object Type
Usage
Function Drop Conflict Popup Default
If the booking conflict pop-up applet is not specified, this user property is used to specify the default operation to be performed when a booking conflict occurs.
Value
OptionFunction
Parent Object Type
Usage
Function Drop Conflict Popup Name
Value
TNT SHM Function Option/Overbook Popup Applet
Parent Object Type
Usage
Grid Background Color
This user property is used to set the background color of the Function Space Diary Grid.
Value
16777215
Parent Object Type
Usage
Grid Line Color
This user property is used to set the line color of the Function Space Diary Grid.
Value
13421772
Parent Object Type
Usage
Grid Line Style
This user property is used to specify the style for the Function Space Diary Grid lines.
Value
0
Parent Object Type
Usage
Ignore Case Sensitivity
This user property is used to control the case sensitivity for comparing function space strings and the string entered in the Go To field.
Value
Y
Parent Object Type
Usage
Ineffective Field
This user property is used to specify the field from which the Function Space Diary retrieves the information about whether or not the function space is ineffective.
Value
Is Ineffective
Parent Object Type
Usage
In the Function Space Diary, if a function space is ineffective, then the Diary displays the ineffective bar. This user property is used to specify the field from which the Diary retrieves the information about whether or not the function space is ineffective.
Item Admin Color BC Name
This user property is used to specify the business component from which colors for different function space statuses are defined in the Function Space Administration view.
Value
TNT SHM Gantt AX Admin Function Status
Parent Object Type
Usage
Item Admin Color BO Name
This user property is used to specify the business object from which colors for different function space statuses are defined in the Function Space Administration view.
Value
System Preferences
Parent Object Type
Usage
Item Admin Special Control BC Name
This user property is used to specify the name of the business component from which information about specialized controls such as setup time pattern and tear-down time pattern is collected.
Value
TNT SHM Gantt AX Admin Specialized Controls
Parent Object Type
Usage
Item BC Assignable Field
This user property is used to specify the field from which the required value (Assignable) is retrieved.
Value
Assignable
Parent Object Type
Usage
Item BC Dependency Field
This user property is used to specify the field from which the required value (Dependency) is retrieved.
Value
Dependency
Parent Object Type
Usage
Item BC Drillable Field
This user property is used to specify the field from which the required value (Drillable) is retrieved.
Value
Drillable
Parent Object Type
Usage
Item BC Editable Field
This user property is used to specify the field from which the required value (Editable) is retrieved.
Value
Editable
Parent Object Type
Usage
Item BC Inventory Status Field
This user property is used to specify the field from which the required value (Inventory status) is retrieved.
Value
Inventory Status
Parent Object Type
Usage
Item Border Style Fields
This user property is used to specify the dimensions for the duration bars in the Function Space Diary.
Value
7;3;11;0
Parent Object Type
Usage
Each booking item is displayed as a time duration bar on the Function Space Diary page. The bar is composed of four smaller bars, representing setup time, configured space booking, tear down time, and a time block that is currently not used in the application. This user property is used to specify the dimensions for each of these bars.
Item Border Style No Setup Time Fields
This user property is used to specify the dimensions for booking items in the Function Space Diary when there is no setup time for the function space.
Value
0;7;11;0
Parent Object Type
Usage
Each booking item is displayed as a time duration bar on the Function Space Diary page. The bar is composed of four smaller bars, representing setup time, configured space booking, tear down time, and a time block that is currently not used in the application. This user property is used to specify the dimensions for booking items when there is no setup time for the function space.
Item Border Style No Teardown Time Fields
This user property is used to specify the dimensions for booking items in the Function Space Diary when there is no teardown time for the function space.
Value
7;11;0;0
Parent Object Type
Usage
Each booking item is displayed as a time duration bar on the Function Space Diary page. The bar is composed of four smaller bars, representing setup time, configured space booking, tear down time, and a time block that is currently not used in the application. This user property is used to specify the dimensions for booking items when a user deselects the turn time flag on the applet.
Item Border Style No Turn Time Fields
Value
0;15;0;0
Parent Object Type
Usage
Item Business Component
This user property is used to specify the business component used by the booking item.
Value
TNT SHM Compact Function Booking VBC
Parent Object Type
Usage
Item Drag Method
This user property is used to specify the method name when a booking item is dragged on the Gantt chart.
Value
InvokeDragItem
Parent Object Type
Usage
Item Drilldown Assignment
This user property is used to specify the drill-down link for each bar in the Function Space Diary booking item.
Value
Item Drilldown;Item Drilldown;Item Drilldown;Item Drilldown
Parent Object Type
Usage
Each booking item is displayed as a time duration bar on the Function Space Diary page. The bar is composed of four smaller bars, representing setup time, configured space booking time, tear-down time, and a time block that is currently not used in the application. This user property is used to specify the drill-down link for each bar in the booking item.
Item Drilldown Src Field Substitutes
This user property specifies the destination that Siebel Hospitality displays when a user clicks a booking item. Use this user property to navigate to the destination view when drilling down on the booking in the Function Space Diary.
Value
Item Drilldown;Quote Id
Parent Object Type
Usage
This user property specifies the destination that Siebel Hospitality displays when a user clicks a booking item. If Quote Id is specified when a user drills down on the booking in the Function Space Diary, this user property navigates to the Quotes screen, Functions view. If Function Id is specified when a user drills down on the booking in the Function Space Diary, this user property navigates to the Functions screen.
Item Fill Style Fields
Value
Setup Time;Configured Space Booking;Tear Down Time;Tear Down Time
Parent Object Type
Usage
Each booking item is displayed as a time-duration bar on the Function Space Diary page. The bar is composed of four smaller bars, representing setup time, configured space booking time, tear-down time, and a time block that is currently not used in the application.
Item Function Business Component
This user property is used to specify the business component to be used for the Function Booking Item.
Value
TNT SHM FSI Booking
Parent Object Type
Usage
Item Icon Clip Text LIC
This user property is used to specify the icon clip text on the booking item.
Value
Noise;Detail;Suite;Function Scheduling;Do Not Move;Recurring;Host;Affiliate;24 Hour Hold
Parent Object Type
Usage
When a function is created, flags such as Noise, Detail, Suite, and so on are displayed in the function. This user property is used to specify the icon clip text on the booking item.
Item Icon Clip Text LOV Name
This user property is used to specify the list of values from which the clip text is retrieved.
Value
TNT_SHM_GNTAX_ICON_CLIPTEXT
Parent Object Type
Usage
Item Icon Fields
This user property is used to specify the field names to which item icons refer.
Value
Noise Flag;Detail Flag;Suite Flag;Function Schedule Flag;Do Not Move Calc;Sub Recurrence Flag;Host Flag;Affiliate Flag;24 Hour Hold Flag
Parent Object Type
Usage
Item Icon Ids
This user property is used to specify the Ids for item icons.
Value
201;215;216;217;203;218;219;220;202
Parent Object Type
Usage
Item Id Field
This user property is used to specify the field to which each booking item refers.
Value
Booking Id
Parent Object Type
Usage
Item Join Field
This user property is used to specify the link between a booking and a function space.
Value
Function Space Id
Parent Object Type
Usage
Item Left Click Method
This user property is used to specify the method to be called when a user left-clicks a booking item.
Value
InvokeDrillDown
Parent Object Type
Usage
Item Resize Method
This user property is used to specify the method to be called when a booking item is resized.
Value
InvokeDragItem
Parent Object Type
Usage
Item Right Click Method
This user property is used to specify the method to be called when a user right-clicks a booking item.
Value
InvokeAssignItem
Parent Object Type
Usage
Item Segment Left Click Methods
This user property is used to specify the method to be called when a user left-clicks an item segment.
Value
InvokeDrillDown;InvokeDrillDown;InvokeDrillDown;InvokeDrillDown
Parent Object Type
Usage
Item Time Dependency Fields
This user property is used to specify the field from which dependency item information is retrieved.
Value
Absolute Set Up Date Time;Start Date Time;Absolute End Date Time;Absolute Tear Down Date Time
Parent Object Type
Usage
Item Time Dependency Tooltip Fields
This user property is used to specify the field from which dependency ToolTip information is retrieved.
Value
Booking Dependency Tip;Booking Dependency Tip;Booking Dependency Tip;Booking Dependency Tip
Parent Object Type
Usage
Item Time Display Toggle LOV Type
This user property is used to specify the list of values from which the name to be displayed on the booking item is retrieved.
Value
TNT_SHM_GNTAX_FSD_DSP_TOGGLE
Parent Object Type
Usage
This user property is used to specify the list of values from which the name to be displayed on the booking item is retrieved. This user property is used by the Display field in the applet.
Item Time Display Toggle Time Label 0
This user property is used to display the Function Name on the booking item.
Value
Function Name Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 1
This user property is used to display the Function Type on the booking item.
Value
Function Type Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 2
This user property is used to display the Meal Period on the booking item.
Value
Meal Period Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 3
This user property is used to display the Business Type on the booking item.
Value
Business Type Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 4
This user property is used to display the Quote Name on the booking item.
Value
Quote Name Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 5
This user property is used to display the Setup Style on the booking item.
Value
Setup Style Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 6
This user property is used to display the Function Status on the booking item.
Value
Function Status Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 7
This user property is used to display the Event Manager Name on the booking item.
Value
Event Manager Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 8
This user property is used to display the Sales Manager Name on the booking item.
Value
Sales Manager Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 10
This user property is used to display the Account Name on the booking item.
Value
Account Name Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 12
This user property is used to display the Function Start Date on the booking item.
Value
Function Start Date Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 13
This user property is used to display the Function Day on the booking item.
Value
Function Day Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Label 17
This user property is used to display the Inventory Status on the booking item.
Value
Inventory Status Calculated
Parent Object Type
Usage
Item Time Display Toggle Time Tooltip 0
This user property is used to specify the ToolTips to be displayed on the booking item.
Value
Booking Set Up Tip;Booking Tip - Function Name;Booking Tear Down Tip;Booking Tear Down Tip
Parent Object Type
Usage
Item Time Display Toggle Time Tooltip 1
This user property is used to specify the ToolTips to be displayed for the function space booking item.
Value
Booking Set Up Tip;Booking Tip - Function Type;Booking Tear Down Tip;Booking Tear Down Tip
Parent Object Type
Usage
Item Time Display Toggle Time Tooltip 2
Value
Booking Set Up Tip;Booking Tip - Meal Period;Booking Tear Down Tip;Booking Tear Down Tip
Parent Object Type
Usage
Item Time Display Toggle Time Tooltip 3
Value
Booking Set Up Tip;Booking Tip - Business Type;Booking Tear Down Tip;Booking Tear Down Tip
Parent Object Type
Usage
Item Time Display Toggle Time Tooltip 4
Value
Booking Set Up Tip;Booking Tip - Quote Name;Booking Tear Down Tip;Booking Tear Down Tip
Parent Object Type
Usage
Item Time Display Toggle Time Tooltip 5
Value
Booking Set Up Tip;Booking Tip - Setup Style;Booking Tear Down Tip;Booking Tear Down Tip
Parent Object Type
Usage
Item Time Display Toggle Time Tooltip 6
Value
Booking Set Up Tip;Booking Tip - Function Status;Booking Tear Down Tip;Booking Tear Down Tip
Parent Object Type
Usage
Item Time Display Toggle Time Tooltip 7
Value
Booking Set Up Tip;Booking Tip - Event Manager;Booking Tear Down Tip;Booking Tear Down Tip
Parent Object Type
Usage
Item Time Display Toggle Time Tooltip 8
Value
Booking Set Up Tip;Booking Tip - Sales Manager;Booking Tear Down Tip;Booking Tear Down Tip
Parent Object Type
Usage
Item Time Display Toggle Time Tooltip 17
Value
Parent Object Type
Usage
Item Time Fields
This user property is used to specify the fields for booking item segments.
Value
Parent Object Type
Usage
Item Time Ineffective Tooltip Fields
This user property is used to specify the ToolTips to be displayed the function space is ineffective.
Value
Ineffective Tip;Ineffective Tip;Ineffective Tip;Ineffective Tip
Parent Object Type
Usage
Item Time Unavailable Tooltip Fields
This user property is used to specify the ToolTip information to be displayed when the function space is unavailable during the specified time.
Value
Unavailable Tip;Unavailable Tip;Unavailable Tip;Unavailable Tip
Parent Object Type
Usage
Item Tooltip Fields
This user property is used to specify the ToolTips to be displayed when the mouse hovers over each of the booking item segments.
Value
Parent Object Type
Usage
This user property is used to specify the ToolTips to be displayed when the mouse hovers over each of the booking item segments, such as setup time, function name, and teardown time.
Item Type Field
This user property is used to specify the field from which the booking type is retrieved.
Value
Booking Type
Parent Object Type
Usage
Item Unavailable Color Field
This user property is used to specify the field from which the color for unavailable status is retrieved.
Value
Booking Type
Parent Object Type
Usage
Number of Rows to Overlap
This user property is used to control how many function spaces from the previous set are displayed in the next set.
Value
1
Parent Object Type
Usage
When a user navigates to the next set of function spaces, the last function space in the previous set is displayed as the first item in the next set. This user property is used to control how many function spaces from the previous set are displayed in the next set.
Parent BC Date Context Field
This user property is used to specify the Start Date search criteria to be shared among the Function Space Diary pages.
Value
Search Sleeping Room Date
Parent Object Type
TNT SHM SR Inventory Display Dync List Applet - Read Only
TNT SHM SR Inventory Display Dync List applet
TNT SHM SR Inventory Display Dync List Applet - Total Availability
TNT SHM SR Total Transient Avail Dync List Applet
TNT SHM SR Total Avail Room Specific Dync List Applet
TNT SHM Suite Total Avail Room Specific Dync List Applet
TNT SHM Sleeping Room Search Form Applet (No Product LOV)
TNT SHM Function Space Inventory DyncPivot List Applet
Usage
This user property is used to specify the Start Date search criteria to be shared among the Function Space Diary pages. This field is in the parent business component (SHM Site), which allows child business components to share the Date context.
Sell Notes - Special Dates Business Component
This user property is used to specify the business component from which sell notes and special dates information is retrieved.
Value
TNT SHM Property Sell Note VBC
Parent Object Type
Usage
Sell Notes - Special Dates Popup Applet
This user property is used to specify the pop-up applet for sell notes and special dates.
Value
TNT SHM Property Sell Notes Popup Applet
Parent Object Type
Usage
Sell Notes - Special Dates Start Date Field Name
This user property specifies the field name from which the sell notes and special dates start date is retrieved.
Value
Start Date
Parent Object Type
Usage
Slider Width(Height)
This user property is used to set the width of the slider.
Value
5
Parent Object Type
Usage
Start Date
This user property is used to retrieve the Start Date for the Function Space Diary.
Value
Start Date
Parent Object Type
Usage
Time BC Start Time Field
This user property is used to specify the Start Date and Start Time for the Function Space Diary.
Value
Start Date Time
Parent Object Type
Usage
Time Business Component
This user property is used to specify the business component for the Gantt chart.
Value
TNT SHM Gantt AX Date Time Interval PopUp VBC
Parent Object Type
Usage
TNT CMT Same Time Frame - Show Move Popup Applet
This user property is used to controls whether or not to show the Move pop-up window in this applet when a booking is dragged and dropped on a time where another booking already exists.
Value
Y
Parent Object Type
Usage
Controls whether or not to show the Move pop-up window in this applet when a booking is dragged and dropped d on a time where another booking already exists. If the value of this user property is Y, the Move pop-up window is displayed. Otherwise, the Move pop-up window is not displayed.
Unavailable Field
This user property is used to retrieve information about whether or not a function space is unavailable.
Value
Is Unavailable Out of Order
Parent Object Type
Usage
X Axis Popup Height
This user property is used to set the height of the pop-up applet.
Value
450
Parent Object Type
Usage
X Axis Popup Width
This user property is used to set the width of the pop-up applet.
Value
600
Parent Object Type
Usage
X-Axis Background Color
This user property is used to set the background color of the x-axis (major and minor axis) of the Gantt chart.
Value
15790320
Parent Object Type
Usage
X-Axis Height
This user property is used to specify the height of the x-axis.
Value
40
Parent Object Type
Usage
X-Axis Line Color
This user property is used to specify the line color for the x-axis.
Value
13421772
Parent Object Type
Usage
X-Axis Line Style
This user property is used to specify the line style of the x-axis.
Value
0
Parent Object Type
Usage
Y Axis Join Field
This user property is used to specify the link between the booking item and the specific space.
Value
Room Id
Parent Object Type
Usage
Y-Axis Background Color
This user property is used to specify the background color for the y-axis of the Gantt chart.
Value
16777215;16777215;16777215;16777215
Parent Object Type
Usage
Y-Axis Business Component
This user property is used to specify the business component for the y-axis.
Value
TNT SHM Compact Room Rel VBC
Parent Object Type
Usage
Y-Axis Draw Sides
This user property is used to draw the sides of the y-axis with the specified values as the widths of the top, left, bottom, and right lines respectively.
Value
2;2;2;2
Parent Object Type
Usage
Y-Axis Drilldown Index Field
This user property is used to specify the index field for the y-axis drill-down destination.
Value
Parent Object Type
Usage
Y-Axis Drilldown Src Field Substitutes
This user property is used to specify the y-axis drill-down destination fields.
Value
Category Space Drilldown;Room Property Id;Specific Space Drilldown;Room Property Id
Parent Object Type
Usage
Y-Axis Header Background Color
This user property is used to set the background color for the y-axis header.
Value
15790320
Parent Object Type
Usage
Y-Axis Header Label Text
This user property is used to specify the label text for the y-axis header.
Value
Specific Space
Parent Object Type
Usage
Y-Axis Header Line Color
This user property is used to specify the color of the y-axis header line.
Value
13421772
Parent Object Type
Usage
Y-Axis Header Line Style
This user property is used to specify the line style of the y-axis header.
Value
0
Parent Object Type
Usage
Y-Axis Hierarchy
This user property is used to display the individual specific spaces in the function space category.
Value
Y
Parent Object Type
Usage
Function space categories are displayed in tree format on the y-axis. To display the individual specific spaces in the category, set this user property value to Y.
Y-Axis Hierarchy Drilldown Assignment
This user property is used to specify drill-down destinations for the y-axis hierarchy.
Value
Specific Space Drilldown;Category Space Drilldown
Parent Object Type
Usage
This user property is used to specify drill-down destinations for the y-axis hierarchy. The first value is for specific space drill-down destinations and the second value is for category drill-down destinations.
Y-Axis Item Dimensions
This user property is used to set the dimensions of the y-axis item.
Value
0;20;40;520
Parent Object Type
Usage
Y-Axis Item Fields
This user property is used to specify the fields for the icons on the y-axis.
Value
Room Backup Required Id;Hierarchy Bitmap Id;Room Name Display;Room Name Display
Parent Object Type
Usage
Each y-axis item is divided into four parts, which are Backup Required icon, Hierarchy icon, Function Space label, and another label. This user property is used to specify the fields for the icons on the y-axis.
Y-Axis Item Font Colors
This user property is used to set the font colors for y-axis items (function spaces).
Value
13408614;13408614;13408614;13408614
Parent Object Type
Usage
Y-Axis Item Icons
This user property is used to specify the icon Ids for y-axis items.
Value
207;206;210;204
Parent Object Type
Usage
This user property is used to specify the icon Ids for y-axis items such as Backup Required and so on.
Y-Axis Item Tooltip Fields
This user property is used to specify ToolTips to be displayed for y-axis items.
Value
;;Room ToolTip;Room ToolTip
Parent Object Type
Usage
Y-Axis Item Types
This user property is used to specify the icon types for y-axis items.
Value
GIcon;GIcon;GLbl;GLbl
Parent Object Type
Usage
Y-Axis Left Click Methods
This user property is used to specify the method to be called when a user left-clicks a y-axis item.
Value
;InvokeToggleChildren;InvokeDrillDown;
Parent Object Type
Usage
Y-Axis Line Color
This user property is used to set the line color on the y-axis.
Value
13421772;13421772;13421772;13421772
Parent Object Type
Usage
Y-Axis Line Style
This user property is used to set the line style on the y-axis.
Value
0;0;0;0
Parent Object Type
Usage
Y-Axis Line Width
This user property is used to specify the line width on the y-axis.
Value
1;1;1;1
Parent Object Type
Usage
Y-Axis Row Type Field
This user property is used to specify the type of the y-axis row.
Value
Room Type
Parent Object Type
Usage
Y-Axis Width
This user property is used to specify the width of the Y-axis.
Value
Function Space Column Size
Parent Object Type
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary
Usage
This user property specifies the width of the Y-axis. The value of this user property is a column name in the User Preferences business component. This allows users to set their preferences for Y-axis width in the User Preferences screen.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
