Implementing Siebel Business Applications on DB2 for z/OS > Preparing for Implementation on the DB2 Host > Process of Setting Up DB2 Connect >
Configuring DB2 Connect EE, ASE or UE to Support Siebel Web Client
This task is a step in Process of Setting Up DB2 Connect.
Using DB2 Connect EE, ASE or UE to support the Siebel Web Client involves:
  • A Siebel Server, running Application Object Managers to support the Siebel Web Client. In some cases, DB2 Connect EE is also installed on this computer.
  • Optionally, an additional computer on which you install DB2 Connect EE, to act as a gateway to the database.
  • DB2 for z/OS.
  • Individual workstations running Siebel Web Client.
This approach is illustrated in the middle and lower parts of Figure 1.
Perform the following steps to configure DB2 Connect EE for a server computer.
To connect to DB2 using DB2 Connect EE
  1. Using vendor instructions, install DB2 Connect EE on a server computer.
    The DB2 Connect EE Server computer functions as a DB2 server, with protocol support for DB2 for z/OS.
    You can also add DB2 Connect to an existing server on which DB2 is already installed.
  2. On the DB2 Connect computer, upgrade DB2 Connect to the appropriate Fix Pack.
    For further information, see About the Required IBM Fix Packs.
  3. On the DB2 Connect EE Server computer, catalog your DB2 for z/OS database, as appropriate, using the DB2 Client Configuration Assistant or the DB2 Command Line Processor.
    After installation, use a standard DB2 client to access the DB2 Connect EE Server.
Implementing Siebel Business Applications on DB2 for z/OS Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
