Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Configuring Siebel Loyalty > Requiring Approval for Status Changes of Loyalty TransactionsYou can use Siebel Tools to change the user properties that specify whether or not an approval is required for changes in transaction status. If approval is required, then the Approval dialog box appears. The user properties End Transition x (where x is a number) on the LOY Transaction business component control whether an approval is required for a particular status change, and so control whether the popup window is displayed. The standard .srf includes the user properties and values shown in Table 4. If the value exists in this list, then the approval popup is not displayed. You can modify these user properties in Siebel Tools. For more information about Siebel Tools, see Using Siebel Tools. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
