Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > About Getting Started with Siebel LoyaltySiebel Applications Administration Guide covers the set-up tasks that are common to Siebel Business Applications, such as using license keys, defining employees, defining your company's structure, and adding partner companies. It also provides the information that you need to perform data administration and document administration tasks. This guide assumes that you have already installed or completed the upgrade of Siebel Loyalty. If you have not, then see Siebel Installation Guide for the operating system you are using in the Siebel Bookshelf. NOTE: The Siebel Bookshelf is available on Oracle Technology Network (http://www.oracle.com/technetwork/indexes/documentation/index.html) and Oracle Software Delivery Cloud. It might also be installed locally on your intranet or on a network location. Siebel Installation Guide for the operating system you are using describes how to create the Siebel Administrator account that is used to perform the tasks described in this guide. In addition to the preliminary set-up tasks covered in this chapter, two major set-up tasks for Siebel Loyalty are covered in other chapters: |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
