Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > About Implementing Siebel Open UIYou can choose to deploy Siebel Business Applications with the Siebel Open UI user interface framework. Siebel Open UI uses an open architecture that enables you to customize and extend the Siebel user interface for your enterprise and, for Siebel employee and partner-facing applications, it provides an alternative to the high-interactivity client. In the current version of Siebel Loyalty, all Siebel Loyalty functionality is available with Siebel Open UI. The procedures in this guide assume that if you are using Siebel Open UI, you do not use left-hand navigation. However, you can set up left-hand navigation if you choose. For information about implementing left-hand navigation, see Siebel Fundamentals for Siebel Open UI. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
