Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Setting Up Server Components for Siebel Loyalty > Setting Up the Interactive Server ComponentThe interactive component is used for handling real-time simulation calls and also for processing low-volume accrual imports from an external system. You can modify the interactive component parameters described in the following procedure to optimize load balancing: To set parameters for the Loyalty Engine interactive component
The interactive processing component runs in the address space of the Siebel EAI Application Object Manager process when processing Web services, instead of in its own address space. As a result, you do not have to start the Loyalty Engine interactive component to enable Siebel Loyalty Web services processing. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
