Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Setting Up Server Components for Siebel LoyaltyThere are three Siebel Enterprise server components defined for the Siebel Loyalty Engine:
All Siebel Loyalty Engine server components in a Siebel Enterprise can access updated cache information during Siebel Loyalty transaction processing, even if the components are running on different Siebel Servers. The Siebel Loyalty cache object contains all the active programs and promotions that are required for processing transactions. Because updated cache data is available on all servers running Siebel Loyalty Engine components, you can implement multiple instances of the real-time server component, running on different Siebel Servers, in a Siebel Enterprise. Depending on the version of Siebel CRM that you are using, you can optionally copy the Loyalty Batch Engine to create a second batch engine component. For information on how to copy the Loyalty Batch Engine, and the requirements for doing so, see 1609676.1 (Article ID) on My Oracle Support. The following topics provide information about setting up each of the server components for the Siebel Loyalty Engine:
For additional information about the architecture of the Siebel Loyalty server components, see Siebel Loyalty Engine Reference. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
