Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Setting Parameters for the Siebel Loyalty EngineYou can customize the following Siebel Loyalty Engine parameters: All these parameters apply to the eLoyalty Processing Engine - Batch component. They affect batch processing, not real-time processing. For a description of these parameters, see Parameters Used in Batch Processing. Parameters are commonly used in the following ways:
You can also set parameters to determine how often statements are produced for each tier of a program by using the Statement Frequency and Only If Activity fields of the Program screen, Tier Class, Tiers view. For more information, see Defining Tier Classes and Tiers. Specifying Objects Processed by the Siebel Loyalty EngineYou can specify which objects the Siebel Loyalty Engine processes by using the parameter LOYEngineQueueObjects. Table 5 lists the types of objects that the Siebel Loyalty Engine processes. Specifying How Often the Siebel Loyalty Objects RunYou can set parameters to specify how often the Siebel Loyalty objects run. For example, objects can run weekly, daily, or hourly. This setting applies to Siebel Loyalty objects, not to individual programs. For example, to specify how often the Siebel Loyalty objects run, set the following parameters for the batch component eLoyalty Processing Engine - Batch (alias LoyEngineBatch):
You can also set parameters to specify how often the Siebel Loyalty points expiration engine runs. For example, it can run weekly, daily, or hourly. This setting applies to Siebel Loyalty, not to individual programs. To specify how often the Siebel Loyalty points expiration engine runs, set the following parameters for the batch component eLoyalty Processing Engine - Batch (alias LoyEngineBatch): |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
