Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Defining Lists of Values for Siebel Loyalty >
Defining Loyalty Member Classes
The Member Class picklist is used for classifying members. Typical values can be Agency, Customer, Salesperson. To define Loyalty classes
- Navigate to the Administration - Data screen, List of Values view.
- Query for the Type LOY_MEM_CLASS.
- Edit the records of this type so there is one record with each of the display values that you want for member classes.
- Click Clear Cache.
NOTE: New values do not go into effect unless you click Clear Cache.
