Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Defining Lists of Values for Siebel Loyalty >
Defining Loyalty Member Phases
The Member Phase picklist is used for specifying phases of member types. Typical values are Gold - Phase 1, Gold - Phase 2, Platinum - Phase 1, and Platinum - Phase 2.
To define Loyalty phases
  1. Navigate to the Administration - Data screen, List of Values view.
  2. Query for the Type LOY_MEM_PHASE.
  3. Edit the records of this type so there is one record with each of the display values that you want for member phases.
  4. Click Clear Cache.
    NOTE:  New values do not go into effect unless you click Clear Cache.
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
