Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Defining Lists of Values for Siebel Loyalty >
Defining Loyalty Lounges
The Lounge picklist is used for specifying the lounges that members can use. For example, Platinum members can be allowed to use special lounges. To define loyalty lounges
- Navigate to the Administration - Data screen, List of Values view.
- Query for the Type LOY_LOUNGE_CD.
- Edit the records of this type so there is one record with each of the display values that you want for lounges.
- Click Clear Cache.
NOTE: New values do not go into effect unless you click Clear Cache.
