Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Defining Lists of Values for Siebel Loyalty > Defining Loyalty Airport and City CodesAirline companies must define airport codes for all airports that flights arrive at and depart from. You can select these codes in the From Airport and To Airport drop-down lists when you define products. Optionally, airline companies can define codes for cities, so they can create promotions based on flights between cities, not just based on flights between individual airports. To create promotions based on flights between cities, after creating the city codes, you must map them to airport codes at the program level; you can also map zones to the airport codes, as described in Mapping Zones and Cities to Airports. Defining Airport CodesThe following procedure describes how to define airport codes.
Defining City Codes |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
