Siebel Loyalty Administration Guide > Working with Siebel Loyalty Program Members > About Using Loyalty Member Services > Giving Gift Points from One Loyalty Member to Another Member of the Same ProgramYou can create a transaction to allow one member give gift points to another member of the same program. This transaction is similar to transferring points between members, as described in Transferring Points Between Loyalty Members. The key difference between points transfer and gift points is that a member can give gift points even if the member does not have a large enough balance of points to cover the gift, while a member can transfer points only if the member has a large enough balance to cover the transfer. In addition, you can limit the number of gift points members can give and receive to prevent abuse, as described in Defining Point Gift Setup. You can charge members for this service in cash. You must use the payment mode of pay, and you cannot use pay plus points. To give gift points from one member to another
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
