Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Programs > Modifying Loyalty ProgramsBefore you can modify a Loyalty Program, you must deactivate it. NOTE: You can keep running the cached Loyalty Program while you are modifying it. Once a batch engine's or real-time engine's cache is loaded, you can deactivate a Program or Promotion without impacting the actively running engine components. This cache is loaded when the engine components are started (batch component) or the first processing request is made (real-time component). Changes in the Program become available to users after you reactivate the program and click the Update Cache button.
Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
