Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Programs > Process of Setting Up Loyalty Programs >
Creating Admin Promotions
When you create a new program, you must create admin promotions to assign the points that are calculated by the base promotion to perform the basic processing for the program, such as:
- Adding points to members' balances when they perform accrual transactions.
- Subtracting points from members' balances when they perform redemption transactions.
- Updating vouchers when members perform transactions that use vouchers.
These admin promotions apply to every transaction of every member of the program. You must not make them visible to members as promotions. The admin promotions perform processing in the background. You must create a transaction attribute, which is used by the admin promotion that processes the cancellations. Then you must create and activate the admin promotions. This task is a step in Process of Setting Up Loyalty Programs. Perform the following tasks:
Creating the Transfer Member Id Transaction Attribute
Use this procedure to create the attribute. To create the Transfer Member Id transaction attribute
- Navigate to Administration - Data screen, List of Values view.
- Add an LOV value record with field values as shown in the following table.
Type |
LOY_ATTRIB_FIELDS_TXN |
Display Value |
Transfer Member Id |
Parent LIC |
Order |
19 |
Translate |
False |
For information about adding an LOV value, see the chapter on working with lists of values in Siebel Applications Administration Guide.
- Navigate to the Loyalty Program Administration screen.
- Select the program for which you want to create the admin promotions and clear the program's Active check box.
- Click the hyperlink in the Program Id field.
- Click the Program Level Attributes view tab and click Transaction Attributes on the link bar.
- Create a new transaction attribute record with field values as shown in the following table.
Name |
Field |
Active |
Selected |
- In the loyalty program form in the upper part of the screen, select the program's Active check box and click Update Cache.
Creating the Admin - Accruals Promotion
Use this procedure to create the promotion. To create the Admin - Accruals promotion
- Navigate to the Loyalty Promotions Administration screen.
- Add a new record to the Promotions list, and enter the values that are provided in the following table.
Name |
Admin - Accruals. |
Always Apply |
Y. |
Apply To |
Accrual-Product. |
Admin |
Select the Admin check box. |
Program |
Enter the name of the program. |
Partner |
Enter the partners for the program. |
Product Inclusion |
All Products. |
Point Limit Type |
Unlimited. |
Promotion Start |
Enter one day before today's date. |
Promotion End |
Leave this field blank, because you do not want the admin promotion to expire. |
- Click the Promotion Number (#) field's hyperlink.
- Click the Rules view tab.
- Create the rule for this promotion:
- Add a new record to the Rules list, and enter the values in the following table.
Sequence |
1 |
Name |
Check Points |
Apply To |
Transactions |
- Click the Name field's hyperlink.
- Add a new record to the Criteria list, and enter the values in the following table.
Sequence |
1 |
Name |
Check Points |
Type of Comparison |
Compare to Values |
- In the Compare to Values Detail form, enter the values in the following table.
Object |
Transaction |
Attribute |
Transaction Points |
Condition |
Is Greater Than |
- Add a new record to the Values list and enter 0 in the Value field.
- Click the Actions view tab.
- Add a new record to the Actions list, and enter the values in the following table.
Sequence |
1. |
Name |
Give Points. |
Type |
Assign Points. |
Use From Transaction |
Y. |
Point Type |
Enter the point type given. |
Qualifying |
If the points are qualifying, then select the check box. |
Point Sub Type |
Enter The point subtype given. |
Object |
Transaction. |
Attribute |
Transaction Points. |
Creating the Admin - Cancellation Promotion
Use this procedure to create the promotion. To create the Admin - Cancellation promotion
Name |
Admin - Cancellation. |
Always Apply |
Y. |
Apply To |
Cancellation. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Point Limit Type |
Unlimited. |
Promotion Start |
Promotion End |
- Create a rule for this promotion:
Sequence |
1 |
Name |
Invoke Cancel Action |
Apply To |
Transactions |
Sequence |
1 |
Name |
Invoke Cancel |
Type |
Cancel Transaction |
- Add another new record to the Actions list, and enter the values in the following table.
Sequence |
2 |
Name |
CancelTxnAttributes |
Type |
Invoke Custom Action |
Method |
NOTE: This step is required if your loyalty program receives retroactive transactions.
Sequence |
3 |
Name |
RTC Manual |
Type |
RTC Manual |
Creating the Admin - Gift Promotion
Use this procedure to create the promotion. To create the Admin - Gift promotion
- Copy the Admin - Accruals promotion created in the earlier procedure.
- In the new Loyalty Promotions record, change the following values from the values in the
Admin - Accruals promotion.
Name |
Admin - Gift |
Apply To |
Accrual-Gift |
Leave all other field values the same as in the Admin - Accruals promotion record.
When you copy the Admin - Accruals promotion, Siebel Loyalty also copies its associated Rule. In the Rule copy, leave all values the same.
Creating the Admin - Loan Promotion
Use this procedure to create the promotion. To create the Admin - Loan promotion
Name |
Admin - Loan. |
Always Apply |
Y. |
Apply To |
Loan. |
Admin |
Program |
Partner |
Promotion Start |
Promotion End |
- Create the first rule for this promotion, which assigns points when the loan is made:
Sequence |
1 |
Name |
Loan |
Apply To |
Transactions |
Sequence |
1 |
Name |
Loan |
Compare to Values |
Object |
Transaction |
Attribute |
Transaction Sub Type |
Condition |
Equals |
- Add a new record to the Values list and enter Loan in the Value field.
Sequence |
1 |
Name |
Loan |
Type |
Assign Points |
Y |
Object |
Transaction |
Attribute |
- Create the second rule for this promotion, which redeems points when the loan is repaid:
- In the thread bar, click Promotion:Admin - Loan.
Sequence |
2 |
Name |
Loan Repayment |
Rule Applies To |
Transactions |
- Click the new rule's Name hyperlink.
Sequence |
1 |
Name |
Loan Repayment |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
- Add a new record to the Values list and enter Loan Repayment in the Value field.
Sequence |
1 |
Name |
Loan Repayment |
Type |
Redeem Points |
Y |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
SetLoanBalance |
Type |
Method |
SetLoanBalance |
Creating the Admin - Point Transfer Promotion
Use this procedure to create the promotion. To create the Admin - Point Transfer promotion
Name |
Admin - Point Transfer. |
Always Apply |
Y. |
Apply To |
Point Transfer. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion End |
- Create the first rule for this promotion:
Sequence |
1 |
Name |
Points Transfer |
Apply To |
Transactions |
Sequence |
1 |
Name |
Check Points |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Is Greater Than |
- Add a new record to the Values list and enter 0 (zero) in the Value field.
- Add another new record to the Criteria list, and enter the values in the following table.
Sequence |
2 |
Name |
Check Type |
Compare to Values |
Object |
Transaction |
Attribute |
Transaction Type |
Condition |
Equals |
- Add a new record to the Values list and enter Redemption in the Value field.
Sequence |
1 |
Name |
Redeem Points |
Type |
Redeem Points |
Use from Transaction |
Y |
Object |
Attribute |
Sequence |
2 |
Name |
Create an Accrual Txn |
Type |
Method |
PointTransfer |
- Create the second rule for this promotion:
- In the thread bar, click Promotion:Admin - Point Transfer.
Sequence |
2 |
Name |
Assign Points |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Check Points |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Is Greater Than |
Sequence |
2 |
Name |
Check Type |
Compare to Values |
Object |
Transaction |
Attribute |
Transaction Type |
Condition |
Equals |
- Add a new record to the Values list and enter Accrual in the Value field.
Sequence |
1 |
Name |
Assign Points |
Type |
Assign Points |
Y |
Object |
Transaction |
Attribute |
Creating the Admin - Redemptions Promotion
Use this procedure to create the promotion. To create the Admin - Redemptions promotion
Name |
Admin - Redemption. |
Always Apply |
Y. |
Apply To |
Redemption-Product. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Product Limit Type |
Unlimited. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Check Points |
Apply To |
Transactions |
Sequence |
1 |
Name |
Check Points |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Is Greater Than |
Sequence |
1 |
Name |
Redeem the Points |
Type |
Redeem Points |
Y |
Object |
Transaction |
Attribute |
Creating the Admin - Voucher Promotion
Use this procedure to create the promotion. To create the Admin - Voucher promotion
Name |
Admin - Voucher. |
Always Apply |
Y. |
Apply To |
Voucher. |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Debit Voucher |
Apply To |
Transactions |
Sequence |
1 |
Name |
Debit Voucher Transaction |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Does Not Equal |
- Add a new record to the Values list and enter Cancellation in the Value field.
Sequence |
1 |
Name |
Update Voucher Status |
Type |
Invoke Custom Transaction |
Method |
DebitVoucher |
- In the thread bar, click Promotion:Admin - Voucher.
Sequence |
2 |
Name |
Cancel Redeemed Voucher |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Cancel Voucher Transaction |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
1 |
Name |
Type |
Method |
CancelRedeemedVoucher |
Creating the Admin - Points Purchase Promotion
Use this procedure to create the promotion. To create the Admin - Points Purchase promotion
Name |
Admin - Points Purchase. |
Always Apply |
Y. |
Apply To |
Point Purchase. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Override Payment & Payment Mode are PAY |
Apply To |
Transactions |
Sequence |
1 |
Name |
Check Override Flag |
Compare to Values |
Object |
Transaction |
Attribute |
Override Price Flag |
Condition |
Equals |
- Add a new record to the Values list and enter "Y" in the Value field.
Sequence |
1 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Transaction Amount |
- Add another record to the Actions list, and enter the values in the following table.
Sequence |
2 |
Name |
Purchase Points |
Type |
Method |
PurchasePoints |
- In the thread bar, click Promotion:Admin - Points Purchase.
Sequence |
2 |
Name |
Payment Mode is PAY |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Check Payment Type |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
- Add a new record to the Values list and enter Pay in the Value field.
Sequence |
1 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Purchase Points |
Type |
Method |
PurchasePoints |
Creating the Admin - Transfer Points Promotion
Use this procedure to create the promotion. To create the Admin - Transfer Points promotion
Name |
Admin - Transfer Points. |
Always Apply |
Y. |
Apply To |
Transfer Points. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Enter the promotion start date. |
Promotion End |
Sequence |
1 |
Name |
Apply To |
Transactions |
Sequence |
1 |
Name |
Check Overide Flag |
Compare to Values |
Object |
Transaction |
Attribute |
Overide Price Flag |
Condition |
Equals |
Sequence |
1 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Transfer Points |
Type |
Method |
TransferPoints |
- In the thread bar, click Promotion:Admin - Transfer Points.
Sequence |
2 |
Name |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Transfer Points |
Type |
Method |
TransferPoints |
Creating the Admin - Gift Points Promotion
Use this procedure to create the promotion. To create the Admin - Gift Points promotion
Name |
Admin - Gift Points. |
Always Apply |
Y. |
Apply To |
Gift Points. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Pay without OV-Points 1-500 |
Apply To |
Transactions |
Sequence |
1 |
Name |
OV N |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
2 |
Name |
Payment Mode is Pay |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
3 |
Name |
Compare points Range -Min |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Is Greater Than or Equal To |
- Add a new record to the Values list and enter 1 in the Value field.
Sequence |
4 |
Name |
Compare points Range-Max |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Is Less Than or Equal To |
- Add a new record to the Values list and enter 500 in the Value field.
Sequence |
1 |
Name |
Amount |
Type |
Update Attribute |
Update this attribute: Object |
Transaction |
Update this attribute: Attribute |
Amount |
Update this attribute: Action |
Set |
With this attribute: Object |
Transaction |
With this attribute: Attribute |
Amount |
And/or this value: Operator |
Multiply |
And/or this value: Value |
.5 |
Sequence |
2 |
Name |
Gift Points Action Type |
Type |
Method |
GiftPoints |
- In the thread bar, click Promotion:Admin - Gift Points.
Sequence |
2 |
Name |
Pay With OV |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
OV N |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
- Add a new record to the Values list and enter Y in the Value field.
Sequence |
2 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Amount |
Type |
Update Attribute |
Transaction |
Amount |
Set |
Transaction |
Amount |
Multiply |
1 |
Sequence |
2 |
Name |
Type |
Method |
GiftPoints |
- Create the third rule for this promotion:
Sequence |
3 |
Name |
Pay without OV-Base Member |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
OV N |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
- Add a new record to the Values list and enter N in the Value field.
Sequence |
2 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
2 |
Name |
Member Tier |
Compare to Values |
Object |
Member |
Attribute |
HM Tier Class 1 |
Condition |
Equals |
- Add a new record to the Values list and enter Base in the Value field.
Sequence |
1 |
Name |
Amount |
Type |
Update Attribute |
Transaction |
Amount |
Set |
Transaction |
Amount |
Multiply |
1 |
Sequence |
2 |
Name |
Type |
Method |
GiftPoints |
Creating the Admin - Availment Promotion
Use this procedure to create the promotion. To create the Admin - Availment promotion
Name |
Admin - Availment. |
Always Apply |
Y. |
Apply To |
Redemption-Availment. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion start date. |
Promotion End |
Sequence |
1 |
Name |
Avail Voucher |
Apply To |
Transactions |
Sequence |
1 |
Name |
Avail Voucher |
Type |
Method |
AvailVoucher |
Creating the Admin - Voucher Reissue Promotion
Use this procedure to create the promotion. To create the Admin - Voucher Reissue promotion
Name |
Admin - Voucher Reissue. |
Always Apply |
Y. |
Apply To |
Voucher Reissue. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Override Price Case |
Apply To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
2 |
Name |
Check Transaction Points |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Is Greater Than |
Sequence |
1 |
Name |
Redeem Points |
Type |
Redeem Points |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Reissue Voucher |
Type |
Method |
ReissueVoucher |
- In the thread bar, click Promotion:Admin - Voucher Reissue.
Sequence |
2 |
Name |
Check Points and Reissue Voucher |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Is Greater Than |
Sequence |
1 |
Name |
Redeem Points |
Type |
Redeem Points |
Point Type |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Reissue Voucher |
Type |
Method |
ReissueVoucher |
Sequence |
3 |
Name |
Reissue Voucher |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Reissue Voucher |
Type |
Method |
ReissueVoucher |
Creating the Admin - Bonus Promotion
Use this procedure to create the promotion. To create the Admin - Bonus promotion
Name |
Admin - Bonus. |
Always Apply |
Y. |
Apply To |
Accrual Bonus. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Assign Points |
Apply To |
Transactions |
Sequence |
1 |
Name |
Check Product |
Compare to Values |
Object |
Transaction |
Attribute |
Product Name |
Condition |
Equals |
- Add a new record to the Values list and enter Product ID in the Value field.
Sequence |
1 |
Name |
Assign Point |
Type |
Assign Points |
Point Type |
Object |
Transaction |
Attribute |
Creating the Admin - Lounge Purchase Promotion
Use this procedure to create the promotion. To create the Admin - Lounge Purchase promotion
Name |
Admin - Lounge Purchase. |
Always Apply |
Y. |
Apply To |
Lounge Purchase. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Override Payment and Payment Mode are PAY |
Apply To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
2 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Lounge Purchase |
Type |
Method |
LoungePurchase |
- In the thread bar, click Promotion:Admin - Lounge Purchase.
Sequence |
2 |
Name |
Override Payment and Payment Mode are Points |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
2 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
- Add a new record to the Values list and enter Points in the Value field.
Sequence |
1 |
Name |
Update Points |
Type |
Redeem Points |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Lounge Purchase |
Type |
Method |
LoungePurchase |
Sequence |
3 |
Name |
Override Payment and Payment Mode are POINTS plus PAY |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
2 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
- Add a new record to the Values list and enter Points_Pay in the Value field.
Sequence |
2 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Sequence |
3 |
Name |
Lounge Purchase |
Type |
Method |
LoungePurchase |
- Create the fourth rule for this promotion:
Sequence |
4 |
Name |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
- Add a new record to the Values list and enter PAY in the Value field.
Sequence |
1 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Lounge Purchase |
Type |
Method |
LoungePurchase |
- Create the fifth rule for this promotion:
Sequence |
5 |
Name |
Payment Mode is POINTS |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Update Points |
Type |
Redeem Points |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Lounge Purchase |
Type |
Method |
LoungePurchase |
- Create the sixth rule for this promotion:
Sequence |
6 |
Name |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Update Points |
Type |
Redeem Points |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Sequence |
3 |
Name |
Lounge Purchase |
Type |
Method |
LoungePurchase |
Creating the Admin - Membership Renewal Promotion
Use this procedure to create the promotion. To create the Admin - Membership Renewal promotion
Name |
Admin - Membership Renewal. |
Always Apply |
Y. |
Apply To |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Overide Payment and Payment Mode are PAY |
Apply To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Membership Renewal |
Type |
Method |
RenewMember |
- In the thread bar, click Promotion:Admin - Membership Renewal.
Sequence |
2 |
Name |
Override Payment and Payment Mode are POINTS |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
2 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Update Points |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Type |
Method |
RenewMember |
Sequence |
1 |
Name |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
2 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Update Points |
Type |
Redeem Points |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Sequence |
3 |
Name |
Type |
Method |
RenewMember |
Sequence |
4 |
Name |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Type |
Method |
RenewMember |
Sequence |
5 |
Name |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Update Points |
Type |
Redeem Points |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Type |
Method |
RenewMember |
Sequence |
6 |
Name |
Payment Mode is POINTS plus PAY |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Update Points |
Type |
Redeem Points |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Transaction |
Attribute |
Sequence |
3 |
Name |
Type |
Method |
RenewMember |
Creating the Admin - Member Enrollment Promotion
This promotion allows members to enroll in programs. Use this procedure to create the promotion. To create the Admin - Enrollment promotion
Name |
Admin - Enrollment. |
Always Apply |
Y. |
Apply To |
Enrollment. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Apply To |
Transactions |
Sequence |
1 |
Name |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
1 |
Name |
Update Pay |
Type |
Update Attribute |
Object |
Creating the Admin - Manual Credit Promotion
Use this procedure to create the promotion. To create the Admin - Manual Credit promotion
Name |
Admin - Manual Credit. |
Always Apply |
Y. |
Apply To |
Manual Credit. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Enter the name of the rule. |
Apply To |
Transactions |
Sequence |
1 |
Name |
Give Points |
Type |
Assign Points |
Point Type |
Object |
Transaction |
Attribute |
Creating the Admin - Manual Debit Promotion
Use this procedure to create the promotion. To create the Admin - Manual Debit promotion
Name |
Admin - Manual Debit. |
Always Apply |
Y. |
Apply To |
Manual Debit. |
Admin |
Program |
Partner |
Product Inclusion |
All Products. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Apply To |
Transactions |
Sequence |
1 |
Name |
Redeem Points |
Type |
Redeem Points |
Point Type |
Object |
Transaction |
Attribute |
Creating the Admin - Promotion Enrollment Promotion
Use this procedure to create the promotion. To create the Admin - Promotion Enrollment promotion
Name |
Promotion Enrollment. |
Always Apply |
N. |
Apply To |
Admin |
Select this checkbox. |
Program |
Partner |
Enter the name of the partner. |
Product Inclusion |
All Products. |
Point Limit Type |
Unlimited. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Override Payment & Payment Mode are Pay for (include Promotion name here) |
Apply To |
Transactions |
- Click the Criteria view tab.
Sequence |
1 |
Name |
Check Payment Mode |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
2 |
Name |
Check Override Price Flag |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
3 |
Name |
Enroll Promotion |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Enrolled Promotion Id |
Condition |
Equals |
- Add a new record to the Values list and enter the enrolled promotion Id in the Value field.
NOTE: You can display the enrolled promotion Id by pressing Ctrl-Alt-K while highlighting the promotion in Promotions view.
Sequence |
1 |
Name |
Update Amount. |
Type |
Update Attribute. |
Transaction. |
Amount. |
Set. |
Transaction. |
Amount. |
And/Or this value |
Leave this section blank. |
Sequence |
2 |
Name |
Enroll to Promotion |
Type |
Promotion Enrollment |
NOTE: No additional detail is needed for this action.
Sequence |
3 |
Name |
Update Incentive choice. |
Type |
Update Attribute. |
Member. |
Select the Member attribute for the incentive choice. There are as many member attributes for incentive choices as the number of promotions that require enrollment. You must select the Member attribute for the incentive choice that contains the promotion number for the current promotion. |
Set. |
Transaction. |
Select the Transaction attribute for the Promotion Incentive Choice. |
And/Or this value |
Sequence |
2 |
Name |
Override payment & Payment mode are Points |
Apply To |
Transactions |
Sequence |
1 |
Name |
Check Payment mode |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
2 |
Name |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
3 |
Name |
Enroll Promotion |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
1 |
Name |
Type |
Sequence |
2 |
Name |
Redeem Points. |
Type |
Redeem Points. |
Point Type: Use From Transaction |
Point Type: Point Type |
Leave this field blank. |
From this attribute: Object |
Transaction. |
From this attribute: Attribute |
And/Or this value |
Sequence |
3 |
Name |
Update Incentive Choice. |
Type |
Update Attribute. |
Update this Attribute: Object |
Member. |
Set. |
Transaction. |
And/Or this value |
Sequence |
3 |
Name |
Override payment & Payment mode are Points plus Pay |
Apply To |
Transactions |
Sequence |
1 |
Name |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
- Add a new record to the Values list and enter Points plus (+) Pay in the Value field.
Sequence |
2 |
Name |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
3 |
Name |
Enroll Promotion |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
1 |
Name |
Update Amount. |
Type |
Update Attribute. |
Transaction. |
Amount. |
Set. |
Transaction. |
Amount. |
And/Or this value |
Sequence |
2 |
Name |
Type |
Sequence |
3 |
Name |
Redeem Points. |
Type |
Redeem Points. |
Transaction. |
And/Or this value |
Sequence |
4. |
Name |
Type |
Update Attribute. |
Member. |
Set. |
Transaction. |
And/Or this value |
Sequence |
4 |
Name |
Apply To |
Transactions |
Sequence |
1 |
Name |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
2 |
Name |
No override |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
3 |
Name |
Enroll Promotion |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
1. |
Name |
Update Amount. |
Type |
Update Attribute. |
Transaction. |
Amount. |
Set. |
Transaction. |
Amount. |
And/Or this value |
Sequence |
2 |
Name |
Type |
Sequence |
3. |
Name |
Type |
Update Attribute. |
Member. |
Set. |
Transaction. |
And/Or this value |
Sequence |
5 |
Name |
Payment mode is Points |
Apply To |
Transactions |
Sequence |
1 |
Name |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
2 |
Name |
No Override |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
3 |
Name |
Enroll Promotion |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
1 |
Name |
Type |
Sequence |
2. |
Name |
Redeem Points. |
Type |
Redeem Points. |
Transaction. |
And/Or this value: Value |
Sequence |
3. |
Name |
Type |
Update Attribute. |
Member. |
Set. |
Transaction. |
And/Or this value |
Sequence |
6 |
Name |
Payment mode is Points plus Pay |
Apply To |
Transactions |
Sequence |
1 |
Name |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Payment Type Code |
Condition |
Equals |
Sequence |
2 |
Name |
No override |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
3 |
Name |
Enroll Promotion |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
1. |
Name |
Update Amount. |
Type |
Update Attribute. |
Transaction. |
Amount. |
Set. |
Transaction. |
Amount. |
And/Or this value |
Sequence |
2 |
Name |
Type |
Sequence |
3. |
Name |
Redeem Points. |
Type |
Redeem Points. |
Transaction. |
And/Or this value |
Sequence |
3. |
Name |
Type |
Update Attribute. |
Member. |
Set. |
Transaction. |
And/Or this value |
Creating the Admin - Points Reactivation Promotion
Use this procedure to create the promotion. To create the Admin - Points Reactivation promotion
Name |
Points Reactivation. |
Always Apply |
N. |
Apply To |
Reactivation. |
Admin |
Select the Admin checkbox. |
Program |
Partner |
Product Inclusion |
All Products. |
Point Limit Type |
Unlimited. |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Pay without override |
Apply To |
Transactions |
Sequence |
1 |
Name |
Override flag is N |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
1 |
Name |
Update Amount |
Type |
Update Attribute. |
Transaction. |
Amount. |
Set. |
Transaction. |
Amount. |
And/Or this value |
Sequence |
2 |
Name |
Reactivate Points |
Type |
Points Reactivation |
Sequence |
2 |
Name |
Pay with override |
Apply To |
Transactions |
Sequence |
1 |
Name |
Override flag is y |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
1. |
Name |
Update Amount. |
Type |
Update Attribute. |
Transaction. |
Amount. |
Set. |
Transaction. |
Amount. |
And/Or this value |
Sequence |
2 |
Name |
Reactivate Points |
Type |
Activating the Admin Promotions
Use this procedure to activate the promotions. To activate the admin promotions
- Select the promotions with the following names:
- Admin - Accruals
- Admin - Cancellation
- Admin - Gift
- Admin - Loan
- Admin - Point Transfer
- Admin - Redemptions
- Admin - Voucher
- Admin - Points Purchase
- Admin - Transfer Points
- Admin - Gift Points
- Admin - Availment
- Admin - Voucher Reissue
- Admin - Bonus
- Admin - Lounge Purchase
- Admin - Membership Renewal
- Admin - Enrollment
- Admin - Manual Credit
- Admin - Debit
- Admin - Promotion Enrollment
- Admin - Reactivating Points
- Click Activate.
