Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Programs > Process of Setting Up Loyalty Programs > Defining Program Level Attributes for LoyaltyAttributes can be used when you create promotions. You can define program level attributes that are available to all promotions in a program by using the Program Level Attributes view of the Loyalty Program Administration screen. When you create a promotion, you can also define promotion-specific attributes that are available to only one promotion. You can define program level attributes while you are setting up the program, or you can wait until you are planning promotions for the program. For more information about defining attributes for promotions, see Creating Attributes for Loyalty Programs. This task is a step in Process of Setting Up Loyalty Programs. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
