Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Creating Eligibility PromotionsAn eligibility promotion is a promotion that has rules and criteria but does not have any actions. These types of promotions are used to check the eligibility of a particular member who might be entitled to get a specific set of promotional benefits. For example, it can be used if a set of promotions are only applicable to residents of US who are over the age of 18. Eligibility promotions must be used exclusively in Promotion Designer: the eligibility promotion is executed before the reward promotions in the promotion design, to restrict the reward promotions to a category of members. The subsequent promotions in the promotion design are executed only if the member meets the criteria in the eligibility promotion. For information about Promotion Designer, and how it relates to eligibility promotions, refer to Using Promotion Designer. Eligibility promotions help to improve performance and ease the setup of promotions because you will no longer need to include these criteria in each individual reward promotion you create. Return Values of Eligibility PromotionsSince eligibility promotions do not have user defined actions associated with them, they return only two possible values: Based on these status codes, Siebel Loyalty can decide whether to further process the promotion design for the related transaction. NOTE: An eligibility promotion is evaluated only if it is a part of a promotion design. It is not evaluated during normal processing of transactions, even if it has been marked as Active. Procedure for Creating Eligibility PromotionsAn eligibility promotion is created like a reward promotion, with the following key differences:
NOTE: Siebel Loyalty does not support using eligibility rules based on the values assigned to the Account Address or the Household Address attributes. To create an Eligibility Promotion
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
