Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Process of Creating Loyalty Promotions >
Using Promotion Designer
Optionally, you can use Promotion Designer to group and sequence a set of promotions in a loyalty program. Promotion Designer lets you fire promotions in a particular sequence, allowing you to validate the sequence of the promotions and calculate the points awarded for a particular flow. A single program can include both promotions that are enabled for Promotion Designer and promotions that are not Promotion-Designer enabled. However, during transaction processing, Siebel Loyalty executes a series of checks that verify the combination of the Partner Category of the Partner and the Product Category of the Product within the transaction. If the check validates, then Siebel Loyalty will apply the promotions that are part of the promotion design that is active for the validate Partner and Product category. When you use Promotion Designer, you can also use:
The Promotion Designer Screen
The Promotion Designer screen is the main screen used for creating promotion designs. It has two major sections:
- Promotion Designer Form. The form is at the top of the screen and contains details about the promotion design.
- Promotion Designer. The graphical area where the promotion is designed. It is located below the Promotion Designer form applet and is further subdivided into two sections:
- Objects Explorer. Contains objects representing steps in a promotion design, which can be dragged to the Designer Palette.
- Designer Palette. The objects dragged into this palette correspond to steps within the promotion design. Each object represents a step in the logical flow of the promotion design.
Table 15 lists the objects in the Objects Explorer and describes how they function as steps in the promotion design.
Table 15. Promotion Designer Step Objects Descriptions
Start |
Marks the beginning of the promotion design, and the point from which the rules evaluation begins. |
- A promotion design must and can have only one Start step
- A Start step can be connected to an Eligibility Promotion, Base Promotion, Promotion or a Phase step
End |
Marks the end of the promotion design, and the point at which the rules evaluation ends. |
- A promotion design must and can have only one End step
- The End step can only be connected to one other step
- An End step cannot be connected to a Start step
Eligibility Promotion |
An Eligibility Promotion step has a specific set of rules and criteria but does not have any actions. These types of promotions are used to check the eligibility of a particular member who might be entitled to get a specific set of promotional benefits. If the criteria in the Eligibility Promotion step are not met, then the flow is terminated. |
- A promotion design can only have one Eligibility Promotion step
- An Eligibility Promotion step can be connected to a Start, Base Promotion, Promotion or a Phase step
- An Eligibility Promotion step cannot be connected to a Stop step
Accrual Base Promotion |
An accrual Base Promotion step calculates the base points of an accrual. NOTE: The object immediately following the Base Promotion in a sequence must be promotion whose action assigns transaction points to a selected point type.
- A promotion design can have only one Base Promotion step
- The Base Promotion step must immediately follow the Start step or an Eligibility Promotion step
- The Base Promotion step can be connected to another Promotion or a -Phase step
Redemption Base Promotion |
A redemption Base Promotion step calculates the base points of a redemption. |
- The Base Promotion step can be connected to another Promotion or to a Phase step
Promotion |
A Promotion step is a promotion that is selected from the existing promotions in a program. |
- A promotion design can have multiple Promotion steps, however a specific Promotion cannot be added more than once to a promotion design
- A Promotion step can be connected to another Promotion, Eligibility Promotion, Base Promotion, Phase, Stop or End step
Phase |
A Phase step consists of multiple promotions. Each promotion within a phase uses the same set of inputs that is passed to the Phase step from its predecessor. There is no sequence within a Phase step: all promotions are evaluated in parallel. The output of a Phase step takes into account all of the promotions within the phase: if more than one promotion updates the same attribute, then the final value of the attribute is the union of all the actions. |
- A promotion design can have multiple Phase steps
- A Phase step can be connected to another Promotion, Phase, Stop or End Step
- A Phase Step cannot both be connected to an End Step and Stop Step at the same time
Stop |
The Stop step signifies a break in the processing of the promotion design. If none of the criteria of the promotion to which the Stop step is connected are met, then the execution of the promotion design stops at that step and the promotion points accumulated until that step are applied to the transaction. |
- A promotion design can have none, one or multiple Stop steps
- A Stop Step can only be connected to a Phase or a Promotion
- A Stop step can only be connected to one step
Connector |
A Connector associates two functional steps with one another. The direction of the arrow of the Connector indicates the sequence of steps in the promotion design. |
- A promotion design always has multiple connectors
- A Connector can be connected to another Promotion, Phase, Stop or End step
- A Connector cannot be connected to another Connector
- A Connector has to be connected to at least two steps of type Promotion, Phase, Stop or End
Creating a Promotion Design
Use the following procedure to create a promotion design. To create a promotion design
- Navigate to the Loyalty Promotions Administration screen, then the Promotion Designer view.
- Add a new record and complete the necessary fields. Some fields are described in the following table.
Name |
Enter the name of the Promotion Design. |
Program Name |
Select the program name with which to associate the promotion design. |
Partner Category |
Select the partner category. |
Product Category |
Select the product category. |
Apply To |
Specify Accrual-Product or Redemptions-Product. |
NOTE: If the promotion design is to be applied to Accrual-Product promotions, then a promotion design for each partner is required, if the partner category is different.
- Click on the promotion design created in Step 2.
- Drag and drop objects from the Objects Explorer to the Designer Palette, following the rules defined in Table 15.
After inserting a Promotion, Eligibility Promotion, or a Phase, follow the instructions in the following steps.
- To insert an eligibility promotion step in a promotion design:
- Drag the Eligibility Promotion object from the Objects Explorer and drop it in the Designer Palette.
- Select an Eligibility Promotion from the Pick Promotion list.
NOTE: Only eligibility promotions are listed.
- Click OK.
- To insert a promotion step in a promotion design:
- Drag the Promotion object from the Objects Explorer and drop it in the Designer Palette.
- The Pick Promotion list appears.
NOTE: Only promotion types matching the Apply To of the promotion field are listed.
- Select a promotion.
- Click OK.
- To insert a phase step in a promotion design:
- Drag the Phase object from the Objects Explorer and drop it in the Designer Palette.
NOTE: Adding a phase step to a redemption promotion design is not recommended.
- The Phase Details window appears.
- Enter a Name and Description for the phase.
- To add promotions to the Phase step:
- Click OK to return to the Phase Details window.
- Click OK to close the Phase Details window and save the phase details.
NOTE: Adding promotions that update the same attribute within a phase is not recommended. If subsequent promotions require values from previous promotions within a phase, then these need to be updated using separate transient variables which can then be referenced in separate promotions. For more information about transient variables, refer to Transient Variables.
Validating and Activating the Promotion Design
The Promotion Designer comes with the ability to analyze the entire promotion design and check its consistency. Unless a promotion design is validated successfully it cannot be activated. The validation status of a promotion design is always displayed in the Validation Status bar: a color bar at the top right corner of the promotion design. A green bar signifies that the promotion design has been successfully validated while a red bar signifies that it is invalid. To validate and activate the promotion design
- Click the Validate button on the top left corner of the promotion design.
Clicking the button triggers a validation check of the promotion design. If it is invalid, then the reasons are displayed.
- If there are errors, then correct them.
- Click the Activate button.
The Activate button is enabled only after the promotion design has been successfully validated.
