Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > About Simulating Loyalty Transactions > Overview of Transaction SimulationTransaction simulation can help you understand the impact that promotions will have on Siebel Loyalty transactions when the promotions are made active. Transaction simulations can be created from the following sources:
The information summary in the output of transaction simulation includes: Each of these summary sections contains detailed information about the number or points accrued or redeemed and about vouchers used if same voucher is assigned for all transactions. Other action results, such as attribute updates are summarized separately. For successful promotions, the output contains a detailed summary of the rules, criteria and actions that were processed for successful promotions. For promotions that returned a Not Qualified status, the output includes reasons why the rules did not qualify and why the criteria failed. The output is called an engine waterfall, because it shows all the steps that the Siebel Loyalty engine took to calculate the final value of the promotion for that transaction. The simulation result can be saved as XML files. For information about configuring the path location where these files are saved, refer to Configuring Summary XML File Destinations for Simulations. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
