Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > About Simulating Loyalty Transactions >
Simulating a Single New Transaction
Use the following procedure simulate a single new transaction. To perform a single new transaction simulation
- Navigate to the Loyalty Program Administration screen, then the Programs view.
- Drill-down on a program.
- Click the Simulate Transaction Details tab.
- Click Simulate New Transaction.
- Click New.
- Add the columns that you require.
NOTE: If a column is not visible, then it has not yet been added. You must add the column before adding the transaction details.
- Enter the transaction details.
- Click Simulate
- View the results in the Log applet.
- Click Save To file to save the simulated data to an XML file.
For information about configuring the destination folder for the XML file, refer to Configuring Summary XML File Destinations for Simulations.
