Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Loyalty Promotion Examples >
Example of Creating a Reward-Referrals Promotion
A reward-referrals promotion rewards members for referring other individuals to a loyalty promotion on a social network. The member who receives the referral reward must be specified in the Referred By Member Number field at the time when the new member enrolls.
The reward referrals promotion implements the Reward Referrer action. When implemented in a promotion, the Reward Referrer action causes the Loyalty Engine to create a new transaction by copying the original enroll-member transaction. In the newly-created accrual transaction, the primary member number of the transaction is replaced with the referral member number. The transaction is then processed by the Loyalty Engine to reward the referrer.
The example promotion in this topic shows how to create a promotion that uses the Enroll to Promotion action and the Reward Referrer action to perform the following tasks:
  • Enroll a member into a promotion, and assign a bonus to the member for enrolling
  • Assign a referral bonus to the referrer if a referral member ID is included in the initial enroll transaction
This example assumes that you have already created the loyalty program.
Creating the Promotion Record
As the first step, you must create a promotion record for the reward referrals promotion.
To create the promotion record
  1. Navigate to the Loyalty Promotions Administration screen.
  2. Add a new Promotion record, and complete the necessary fields. Some fields are shown in the following table.
    Field
    Value
    Name
    Reward Referrals
    Always Apply
    Yes
    Apply To
    Promotion Enrollment
    Product Inclusion
    All Products
Specifying the Product for the Promotion
Now, you must associate this promotion with the promotion enrollment product.
To specify the product for this promotion
  1. Click the Promotion Number (#) field.
  2. Click the Products view tab.
  3. Add a new Product record, and complete the necessary fields. Some fields are shown in the following table.
    Field
    Value
    Name
    Part Number (#)
    Loyalty - Member Services
Creating the Attribute to Record if a Referral Member Number Exists
Create a transaction attribute to record whether or not a referral member number exists in the record of the person being enrolled.
To create the attribute that records whether or not a referral member number exists
  1. On the Loyalty Program Administration screen, click the Program Level Attributes tab, then the Transaction Attributes view tab.
  2. Add a new record, and complete the necessary fields. Some fields are shown in the following table.
    Field
    Value
    Name
    Active
    Yes
    Field
    Read Only
    Yes
    Data Type
    String
Creating Rules to Reward Members for Referrals
Create a rule for this promotion to enroll the new member into the promotion and to reward the referring member if a referral member number is provided.
To create rules that enroll new members and reward referring members
  1. Click the Rules view tab.
  2. In the Rules list, add a new record, and complete the necessary fields. Some fields are shown in the following table.
    Field
    Value
    Sequence
    1
    Name
    Referral member number does not exist
    Apply To
    Transactions
  3. Click the rule's Name field hyperlink.
  4. To create the first criterion, add a new record in the Criteria list, and complete the necessary fields as shown in the following table.
    Field
    Value
    Sequence
    1
    Name
    If Referred By Member Number is empty
    Type of Comparison
    Compare to Object
  5. In the Compare to Value Details form, enter the values shown in the following table.
    Field
    Value
    Object
    Transaction
    Attribute
    Select the name of the transaction attribute that you have mapped to the Referred By Member Number field, in this example, Referred By Member Number.
    Condition
    Is Empty
  6. Click the Actions view tab.
  7. Add a new Action record, and complete the necessary fields in the Action list and Detail form, shown in the following table.
    Field
    Value
    Sequence
    1
    Name
    Enroll to Promotion
    Type
  8. Add a new record to the Actions list, and enter the values in the following table.
    Field
    Value
    Sequence
    2
    Name
    Update IC
    Type
    Update Attribute
  9. In the Update Attribute Action form, enter the values in the following table.
    Field
    Value
    Update this attribute: Object
    Member
    Update this attribute: Attribute
    Incentive Choice - promotion_number
    where promotion_number is the row ID of the promotion for which the Incentive Choice is defined.
    Action
    Set
    With this attribute: Object
    Transaction
    With this attribute: Attribute
    Promotion Incentive Choice
  10. Click the Rules view tab.
  11. Create the second rule for this promotion by adding a new record to the Rules list and entering the values shown in the following table.
    Field
    Value
    Sequence
    2
    Name
    Referral member number exists
    Apply To
    Transactions
  12. Click the rule's Name field hyperlink.
  13. To create the first criterion, add a new record in the Criteria list, and complete the necessary fields as shown in the following table.
    Field
    Value
    Sequence
    2
    Name
    If Referred By Member Number is not empty
    Type of Comparison
    Compare to Object
  14. In the Compare to Value Details form, enter the values shown in the following table.
    Field
    Value
    Object
    Transaction
    Attribute
    Condition
    Is Not Empty
  15. Click the Actions view tab.
  16. Add a new Action record, and complete the necessary fields in the Action list and Detail form, shown in the following table.
    Field
    Value
    Sequence
    1
    Name
    Enroll to Promotion
    Type
  17. Add a new record to the Actions list, and enter the values in the following table.
    Field
    Value
    Sequence
    2
    Name
    Update IC
    Type
    Update Attribute
  18. In the Update Attribute Action form, enter the values in the following table.
    Field
    Value
    Member
    Action
    Set
    Transaction
  19. Add a new record to the Actions list, and enter the values in the following table.
    Field
    Value
    Sequence
    3
    Name
    Reward Referrer
    Type
    Reward Referrer
Activating the Promotion
Now that you have set up this promotion, you can activate it.
To activate the promotion
  1. In the thread bar, click Promotion: Reward Referrals.
  2. In the Promotion form, click Activate.
    The promotion is active during the period between the start date and the end date that you chose.
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
