Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Loyalty Promotion Examples >
Example of Creating an Accrual Package Promotion
An accrual package promotion is similar to a joint promotion, in that a member earns a bonus for making purchases from multiple partners, but has the additional ability to split debit points for the bonus among all the partners involved in the promotion, in a specified ratio. For example, within a specific period, a member must do the following to receive 5000 bonus points:
  • Fly Indigo Airways three times AND
  • Stay in Top hotels twice AND
  • Rent a Speedy car three times
The points are debited to the partners Indigo, Top and Speedy in the ratio 2:1:1. To achieve the points split, you associate multiple partners at the accrual package promotion level, rather than associating a single partner at the promotion level.
This example assumes that you have already created the loyalty program and products necessary for the promotion.
Creating a Promotion Record for an Accrual Package Promotion
The first step is to create the promotion record and specify the partners.
To create a promotion record for an accrual package promotion
  1. Navigate to the Loyalty Promotions Administration screen.
  2. Add a new Promotion record, and complete the necessary fields. Some fields are shown in the following table.
    Field
    Value
    Name
    Accrual Package Split Promotion
    Always Apply
    No
    Apply To
    Accrual-Product
    Promotion Start
    1/15/2008
    Promotion End
    7/15/2008
    Product Inclusion
    Include Products
    Accrual Package Flag
    Select this check box
    Partner
    Leave this field blank. You enter the partner names in Step 5.
  3. Click the Promotion number.
    The Promotion form appears.
  4. In the Promotion form, click the Package Accrual Split view tab.
  5. To split the debit among the three partners in the ratio 2:1:1, add three new records, as shown in the following table.
    Record
    Partner Name
    Percentage Split
    1
    Indigo
    50
    2
    Top
    25
    3
    Speedy
    25
Creating Attributes for the Promotion
The next step is to create one attribute each for the three partners associated with the promotion.
To create the attributes for an accrual package promotion
  1. In the Promotion form, click the Promotion Specific Attributes view tab.
  2. Add a new record, and complete the necessary fields. Some fields are shown in the following table.
    Field
    Value
    Name
    Indigo flight
    Active
    Y
    Field
    Number 1
    Default
    0
    Data Type
    Number
  3. Add a new record, and complete the necessary fields. Some fields are shown in the following table.
    Field
    Value
    Name
    Top hotel
    Active
    Y
    Field
    Number 2
    Default
    0
    Data Type
    Number
  4. Add a new record, and complete the necessary fields. Some fields are shown in the following table.
    Field
    Value
    Name
    Speedy car rental
    Active
    Y
    Field
    Number 3
    Default
    0
    Data Type
    Number
Creating Rules to Update Accrual Package Promotion Attributes
The next step is to create rules to update the accrual package promotion attributes when a member makes a purchase from the partners.
To create rules to update accrual package promotion attributes
  1. Click the Rules view tab.
    Field
    Value
    Sequence Number (#)
    2
    Name
    Update number of Indigo flights
    Apply To
    Transactions
  3. Click the rule's Name field hyperlink.
  4. In the Criteria list, add a new record, and complete the necessary fields. Some fields are shown in the following table.
    Field
    Value
    Sequence Number (#)
    1
    Name
    Type of Comparison
    Compare to Values
  5. In the Compare to Values Detail form, enter the values shown in the following table.
    Field
    Value
    Object Number (#)
    Transaction
    Attribute
    Partner
    Condition
    Equals
  6. In the Values list below the Compare to Values Detail form, add a new record and select the partner to use for this promotion, as shown in the following table.
    Field
    Value
    Value
    Indigo
  7. Click the Actions view tab.
  8. In the Actions list, add a new record, and complete the necessary fields. Some fields are shown in the following table.
    Field
    Value
    Sequence Number (#)
    1
    Name
    Type
    Update Attribute
    Update this attribute section
    Object
    Promotion
    Attribute
    Select the Indigo flight promotion
    Action
    Add
    Value
    1
  9. Repeat Step 1 through Step 8 to add rules for Speedy rental and again for Top hotels.
Creating a Rule to Give a Bonus
The next step is to create a rule to give the member a bonus when the member has completed the required flights, hotel stays and car rentals.
The requirement for this rule is that all of the member's promotion-specific attributes are equal to or greater than the required amounts. Use Greater Than rather than Equal To, because the member might have more than the required value for one attribute before reaching the required value for the other.
To create a rule that gives members a bonus
  2. In the Rules list, add a new record, and complete the necessary fields. Some fields are shown in the following table.
    Field
    Value
    Name
    Indigo 3 flights, Top 2 stays, Speedy 3 rentals, get 5,000 Reg NQ points
    Apply To
    Attributes
  4. In the Criteria list, add a new record, and complete the necessary fields shown in the following table.
    Field
    Value
    Sequence
    1
    Name
    Count of Indigo flights greater than or 3
    Type of Comparison
    Compare to Values
  5. In the Compare to Values Detail form, complete the necessary fields shown in the following table.
    Field
    Value
    Object
    Promotion
    Attribute
    Select the Indigo promotion
    Condition
    Is Greater Than
  6. In the Values list below the Compare to Values Detail form, add a new record and select the product that you created for this promotion, as shown in the following table.
    Field
    Value
    Value
    2
  7. In the Criteria list, add another new record, and complete the necessary fields shown in the following table.
    Field
    Value
    Sequence
    2
    Name
    Count of Top hotel stays greater than or equal to 2
    Type of Comparison
    Compare to Values
  8. In the Compare to Values Detail form, complete the necessary fields shown in the following table.
    Field
    Value
    Object
    Promotion
    Attribute
    Select the Top promotion
    Condition
    Is Greater Than
  9. In the Values list below the Compare to Values Detail form, add a new record and select the product that you created for this promotion, as shown in the following table.
    Field
    Value
    Value
    1
  10. In the Criteria list, add another new record, and complete the necessary fields shown in the following table.
    Field
    Value
    Sequence
    3
    Name
    Count of Speedy rentals greater than or equal to 3
    Type of Comparison
    Compare to Values
  11. In the Compare to Values Detail form, complete the necessary fields shown in the following table.
    Field
    Value
    Object
    Promotion
    Attribute
    Select the Speedy promotion
    Condition
    Is Greater Than
  12. In the Values list below the Compare to Values Detail form, add a new record and select the product that you created for this promotion, as shown in the following table.
    Field
    Value
    Value
    2
  13. Click the Actions view tab.
  14. Add a new Action record, and complete the necessary fields in the Action list and Detail form, shown in the following table.
    Field
    Value
    Sequence
    4
    Name
    Give 5,000 Reg NQ points
    Type
    Assign Points
    Point Type
    Regular
    Value
    5000
Activating the Promotion
Now that you have set up this promotion, you can activate it.
To activate the promotion
  1. In the Promotions list, select this promotion.
  2. Click Activate.
    The promotion is active during the period between the start date and the end date. Members receive the bonus points for making the required purchases.
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
