Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Promotions Based on Day or Time of Purchase >
Creating Calendar Attributes
You create calendar attributes at the program level, and they can be used in the criteria of any promotions in that program. To create calendar attributes
- Navigate to the Loyalty Program Administration screen.
- Drill down on the name of the program that you want.
The Active checkbox for the program must be deselected.
- Click the Program Level Attributes view tab.
- Click the Calendar Attributes subtab.
- In the Calendar Attributes view, add a new record, and complete the necessary fields. Some fields are described in the following table.
Name |
Enter a name for the attribute. When you select the attribute in rules, this is the value that you select. |
Active |
Select this checkbox to activate the attribute, making it available for use in promotions in this program. |
Method |
Select the method that returns the value of this attribute. For more information, see About Calendar Attributes. |
Field |
Enter any field of the type Date, depending on the business requirement. |
Data Type |
Displays the data type returned by the method selected in the Method field. |
Pick List |
Displays the picklist for the method selected, as described in Table 30. |
