Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Promotions Based on Day or Time of Purchase >
Creating Promotions Based on Day or Time of Purchase
You create promotions to reward purchases based on the day or time when the purchase was made as you create other promotions, selecting the values described in the following procedure. For more information, see Process of Creating Loyalty Promotions. To create promotions based on day or time of purchase
- Create the needed calendar attributes at the Program level.
For more information, see About Calendar Attributes and Creating Calendar Attributes.
- Create promotions with rules that use these calendar attributes in their criteria. In the Criteria view of the rule, in the Compare to Values form:
- In the Object field, select Calendar.
- In the Attribute field, select one of the calendar attributes defined for the program.
- In the Type of Comparison field, select Compare to Values.
- Use the Condition field and the Values list to specify values that are compared with the value of the attribute, as you do for other promotions that use Compare to Values as the type of comparison.
