Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Redemptions > Process of Setting Up Nonflight Redemptions >
Associating the Nonflight Redemption Product with a Program Partner
Associate the nonflight redemption product with the program partner who provides the product to the customer.
This task is a step in About Nonflight Redemptions.
To associate the redemption product with a program partner
  1. Navigate to the Loyalty Program Administration screen.
  2. Locate the program you want, and click its Program Id field.
  3. Click the Partners view tab.
  4. In the Partner's list, select the partner that you want.
  5. In the Loyalty Product Offerings view for that partner, click New to add the redemption product and complete the necessary fields. Some fields are described in the following table.
    Field
    Description
    Product
    The redemption product that you created in Creating the Flight Redemption Product.
    Start Date
    The start date for the redemption product's association with this partner.
    NOTE:  The start and end dates for the association must be within the start and end dates for the product. The redemption activity can only occur on a date that is within both the product's effective dates and the association's effective dates. It is used for validating the redemption request.
    End Date
    The end date for the redemption product's association with this partner.
    Offer Type
    The type of product offering. Select Redemption from the drop-down list for redemption products.
    Pricing Method
    Select one of the following options:
    NOTE:  For nonflight redemptions, the pricing method must be Points or Base Promotion. Points by Zone and Points by Distance are applicable only for flight redemptions.
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
