Siebel Loyalty Administration Guide > Siebel Loyalty Workflow, Task Flow, and Methods Reference > Siebel Loyalty Workflows > LOY Return Points to Parent Point Block WorkflowThe LOY Return Points to Parent Point Block workflow, shown in Figure 46, returns the remaining points in a point block associated with a promotion to the parent point block from which the points were originally reserved, when the status of that point block is set to Consumed. To process any monetary refunds due from the return, Siebel Loyalty tracks the returned value at the parent point block level. Workflow Description. This workflow performs the following actions: |
Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
