Siebel Loyalty Administration Guide > Siebel Loyalty Workflow, Task Flow, and Methods Reference > LOY Processing Engine Business Service >
UpdateCache Method
UpdateCache updates the Promotion in the Cache, if the engine is already initialized. Input Arguments are summarized in Table 35.
Table 35. Input Arguments
ObjectType |
String |
Type of object to update. If Program, then the loyalty program information is updated. Otherwise, promotion information is updated. |
ProgramId |
Row Id |
Target loyalty program to update. |
PromotionId |
Row Id |
Id of the Promotion to load. |
Output Arguments
None
