Table 154. Summary of Data Bean Methods for Siebel Java Data Bean
Attach Method for an Application |
Allows an external application to reconnect to an existing Siebel session. |
boolean attach(String sessionID) throws SiebelException
CurrencyCode Method for an Application |
Returns the currency code that is associated with the division of the user position. |
String currencyCode()
Detach Method for an Application |
Returns a string that contains the Siebel session ID. |
String detach() throws SiebelException
GetBusObject Method for an Application |
Creates a new instance of a business object. |
SiebelBusObject getBusObject(String boName) throws SiebelException
GetProfileAttr Method for an Application |
Returns the name of an attribute in a user profile. |
String getProfileAttr(String attrName) throws SiebelException
GetService Method for an Application |
Locates a business service. If this business service is not already running, then Siebel CRM starts it. |
SiebelService getService(string serviceName) throws SiebelException
InvokeMethod Method for an Application |
Calls a method. |
String invokeMethod(String name, String[] args) throws SiebelException
Login Method for an Application |
Allows an external application to log in to the COM Data Server, COM Data Control, or Siebel Java Data Bean, and to access Siebel objects. |
boolean login(String connString, String userName, String passWord) throws SiebelException
LoginId Method for an Application |
Returns the login ID of the user who started the Siebel application. |
String loginId()
LoginName Method for an Application |
Returns the login name of the user who started the Siebel application. |
String loginName()
Logoff Method for an Application |
Disconnects the Siebel client from the Siebel Server. |
boolean logoff() throws SiebelException
NewPropertySet Method for an Application |
Creates a new property set. |
SiebelPropertySet newPropertySet()
PositionId Method for an Application |
Returns the position ID of the user position. |
String positionId()
PositionName Method for an Application |
Returns the name of the current user position. |
String positionName()
SetPositionId Method for an Application |
Sets the active position to a Position ID. |
boolean setPositionId(String posId) throws SiebelException
SetPositionName Method for an Application |
Sets the active position to a position name. |
boolean setPositionName(String posName) throws SiebelException
SetProfileAttr Method for an Application |
Personalization uses this method to set a value for an attribute in a user profile. |
boolean setProfileAttr(String attrName,String attrValue) throws SiebelException
Trace Method for an Application |
Appends a message to the trace file. |
boolean trace(String message) throws SiebelException
TraceOff Method for an Application |
Turns off tracing. |
boolean traceOff() throws SiebelException
TraceOn Method for an Application |
Turns on tracing. |
boolean traceOn(String filename, String Category, String selection)throws SiebelException
