Table 155. Summary of Business Component Methods for Siebel Java Data Bean
ActivateField Method for a Business Component |
Activates a field. |
boolean activateField(String fieldName) throws SiebelException
ActivateMultipleFields Method for a Business Component |
Activates multiple fields. |
boolean activateMultipleFields(SiebelPropertySet psFields) throws SiebelException
Associate Method for a Business Component |
Creates a new many-to-many relationship for the parent object through an association business component. |
boolean associate(boolean isInsertBefore) throws SiebelException
BusObject Method for a Business Component |
Returns the name of the business object that the business component references. |
SiebelBusObject busObject() throws SiebelException
ClearToQuery Method for a Business Component |
Clears the current query but does not clear sort specifications on a business component. |
boolean clearToQuery() throws SiebelException
DeactivateFields Method for a Business Component |
Deactivates the fields that are currently active from the SQL query statement of a business component. |
boolean deactivateFields()
DeleteRecord Method for a Business Component |
Removes the current record from a business component. |
boolean deleteRecord() throws SiebelException
ExecuteQuery Method for a Business Component |
Returns a set of business component records. |
boolean executeQuery(boolean cursorMode) throws SiebelException
If using the ExecuteQuery method with Siebel Java Data Bean, use True for ForwardOnly and False for ForwardBackward. |
ExecuteQuery2 Method for a Business Component |
Returns a set of business component records. Allows you to control the number of records Siebel CRM returns. |
boolean executeQuery2(boolean cursorMode, boolean ignoreMaxCursorSize) throws SiebelException
FirstRecord Method for a Business Component |
Moves the record pointer to the first record in a business component, making that record the current record. |
boolean firstRecord() throws SiebelException
GetFieldValue Method for a Business Component |
Returns the value of a field from the current record of a business component. |
String getFieldValue(String fieldName) throws SiebelException
GetFormattedFieldValue Method for a Business Component |
Returns a field value that is in the same format that the Siebel client uses. |
String getFormattedFieldValue(String fieldName) throws SiebelException
GetMultipleFieldValues Method for a Business Component |
Returns values for the fields specified in a property set. |
boolean getMultipleFieldValues(SiebelPropertySet Src, SiebelPropertySet result) throws SiebelException
GetMVGBusComp Method for a Business Component |
Returns the multivalue group business component that is associated a business component field. |
SiebelBusComp getMVGBusComp(String fieldName) throws SiebelException
GetNamedSearch Method for a Business Component |
Returns the name of a search specification. |
String getNamedSearch(String searchName) throws SiebelException
GetPicklistBusComp Method for a Business Component |
Returns the name of the pick business component that is associated with a field in the current business component. |
SiebelBusComp getPicklistBusComp(String fieldName) throws SiebelException
GetSearchExpr Method for a Business Component |
Returns the current search expression that is defined for a business component. |
String getSearchExpr() throws SiebelException
GetSearchSpec Method for a Business Component |
Returns the search specification that is defined for a business component. |
String getSearchSpec(String fieldName) throws SiebelException
GetUserProperty Method for a Business Component |
Returns the value for the specified property. |
String getUserProperty(String property) throws SiebelException
GetViewMode Method for a Business Component |
Returns the visibility mode for a business component. |
int getViewMode()
InvokeMethod Method for a Business Component |
Calls a method. |
String invokeMethod(String methodName, String[] methArg1, methArg2, methArgN) throws SiebelException
LastRecord Method for a Business Component |
Moves the record pointer to the last record in a business component. |
boolean lastRecord() throws SiebelException
Name Method for a Business Component |
Returns the name of a business component. |
String name()
NewRecord Method for a Business Component |
Adds a new record to a business component. |
boolean newRecord(boolean isInsertBefore) throws SiebelException
NextRecord Method for a Business Component |
Moves the record pointer to the next record in a business component, making that record the current record. |
boolean nextRecord() throws SiebelException
ParentBusComp Method for a Business Component |
Returns the name of a parent business component. |
SiebelBusComp parentBusComp() throws SiebelException
Pick Method for a Business Component |
Places the currently chosen record in a pick business component into the appropriate fields of the parent business component. |
boolean pick() throws SiebelException
PreviousRecord Method for a Business Component |
Moves the record pointer to the previous record in a business component, making that record the current record. |
boolean previousRecord() throws SiebelException
RefineQuery Method for a Business Component |
Refines a query. |
boolean refineQuery() throws SiebelException
Release Method for a Business Component |
Releases a business component and the resources for this business component that exist on the Siebel Server. |
void release()
SetFieldValue Method for a Business Component |
Sets a new value in a field for the current record of a business component. |
boolean setFieldValue(String fieldName, String fieldValue) throws SiebelException
SetFormattedFieldValue Method for a Business Component |
Sets a new value in a field in the current record of a business component. It accepts the field value in the current local format. |
boolean setFormattedFieldValue(String fieldName, String fieldValue) throws SiebelException
SetMultipleFieldValues Method for a Business Component |
Sets new values to the multiple fields specified in the property set for the current record of a business component. |
boolean setMultipleFieldValues(SiebelPropertySet psFields) throws SiebelException
SetNamedSearch Method for a Business Component |
Sets a named search specification on a business component. |
boolean setNamedSearch(String searchName, String searchText) throws SiebelException
SetSearchExpr Method for a Business Component |
Sets the search expression for a business component. |
boolean setSearchExpr(String searchExpr) throws SiebelException
SetSearchSpec Method for a Business Component |
Sets the search specification for a business component. |
boolean setSearchSpec(String fieldName, String searchSpec) throws SiebelException
SetSortSpec Method for a Business Component |
Sets the sort specification for a business component. |
boolean setSortSpec(String sortSpec) throws SiebelException
SetUserProperty Method for a Business Component |
Sets the value of a user property in a business component. |
boolean setUserProperty(String propName, String propVal)
SetViewMode Method for a Business Component |
Sets the visibility type for a business component. |
boolean setViewMode(int mode) throws SiebelException
UndoRecord Method for a Business Component |
Reverses any unsaved modifications made to the record. |
boolean undoRecord() throws SiebelException
WriteRecord Method for a Business Component |
Saves to the Siebel database any modifications made to the current record. |
boolean writeRecord() throws SiebelException
