Siebel Object Interfaces Reference > About Object Interfaces and the Programming Environment > About the Siebel Programming EnvironmentThis topic describes the Siebel programming environment. Programming LanguagesYou can use the following programming languages to access object interface methods and object interface events:
For more information, see Using Siebel Visual Basic and Siebel eScript. Server ScriptA Server Script is a type of script that the Siebel Server interprets and runs. You can use the following scripting languages in a Server Script:
For more information, see Using Siebel Visual Basic and Siebel eScript. Browser ScriptA Browser Script is a type of script that the browser interprets and runs. It interacts with the Document Object Model and with the Siebel Object Model in the browser through the Browser Interaction Manager. You write Browser Script in JavaScript. You can script the behavior of Siebel events and the browser events that the Document Object Model makes available. The Document Object Models for Internet Explorer and Netscape Navigator are different. You can use Browser Script only with a Siebel application that runs in high interactivity mode. The only exception is if you script a control event that you use with the Browser Document Object Siebel Model. Siebel CRM version 7 introduced Browser Script. For more information, see Document Object Model Events You Can Use. Do not use Browser Script to manipulate the location of a frame or a form in Siebel CRM because this configuration causes Siebel CRM to load a new page. This configuration is a violation of preferred security practices, so the result is a permission denied error. A high interactivity Siebel application can contain a standard interactivity view. For example, the Home Page view or the Dashboard view. If the Siebel application uses high interactivity or standard interactivity, then you cannot use Browser Script on an applet in these views. Instead, the Siebel application calls the WebApplet_ShowControl Server Script that resides on the applet. For more information, see Browser Script Quick Reference. For information about creating Browser Script, see Configuring Siebel Business Applications. Siebel Script EditorThe Siebel Script Editor is an integrated editor that you can use to create, view, edit, and save custom code. It includes the Script Assist code editor. This editor includes the following features to help reduce errors when you develop a script:
Siebel CRM version 7.8 introduced Script Assist. For more information, see Using Siebel Tools. Siebel DebuggerThe Siebel Debugger is a tool that helps you detect errors that occur in the code of a Siebel programming language. It does not help you detect errors that occur outside of the context of the code. You can configure Siebel CRM to start the Siebel Debugger automatically from a Siebel application if a run-time error occurs. You can also start the debugger from the Debug toolbar or the Debug menu in Siebel Tools. For more information, see Using Siebel Tools. Siebel Compiler and Run-Time EngineThe Siebel Compiler and Run-Time Engine is a nonvisual component of a Siebel programming language that compiles and runs custom code. It is similar to Microsoft's Visual Basic Language Interpreter. Siebel CRM compiles Siebel code and stores it in the SRF file. You can click the Compile icon on the Debugger toolbar in Siebel Tools to start the Siebel Compiler and Run-Time Engine. You can also start it if you compile a project that contains an object definition that is associated with a Siebel script. The Siebel Compiler and Run-Time Engine do not include a user interface. The compiler compiles the custom code, and then returns a message that indicates success or failure. Compilation OrderThe Siebel Compiler compiles Siebel VB functions and procedures in alphabetical order as they occur in the object definition. If a function or procedure calls another function or procedure that is not defined, then the compiler creates an error message that is similar to the following: function_name Is An Unknown Function To avoid this error, you can use the Declare statement to declare the function or procedure in the declarations section of the general section. Siebel eScript does not require you to declare a function before you use it. For more information, see Siebel VB Language Reference. ST eScript EngineThe ST eScript engine is available in Siebel CRM version 7.8 and later. It is the default Siebel eScript scripting engine in Siebel CRM version 8.0 and later. It allows you to use strongly typed objects that are compliant with the ECMAScript edition 4 specification. It also provides early and late binding. For information about:
About Early and Late BindingEarly binding occurs if you bind a specific object instance to a variable. The following code binds an object to a variable at design time. It is an example of early binding: var lo_bo = TheApplication().GetBusObject("Account"); Late binding occurs if you bind an object to a variable only at run time. The following code is an example of late binding: if (TheApplication().ActiveBusObject().Name() == "Account") This late binding code does not specify a specific object. The compiler cannot identify this object and it cannot identify that the Name method is part of the object. Siebel CRM can only bind this object to a variable at run time. Siebel Script ProfilerThe Siebel Script Profiler is a tool that gathers and displays data for the scripts that Siebel CRM runs when you start a Siebel application in Debug mode from Siebel Tools. Siebel Tools displays the profiler data in a window that is similar to the Watch window. It automatically updates information in this window while a script runs in the Siebel application. The Script Profiler includes the following features:
You can use this data to do the following work:
You can use the Script Profiler only with the ST eScript Engine. |
| Siebel Object Interfaces Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
