Table 117. Summary of Application Events for Siebel VB
Application_Close Event |
Allows scripts to perform cleanup, before the Siebel application closes. |
Application_Close
Application_Navigate Event |
Called after the user navigates to a view. |
Application_InvokeMethod Event |
Called after a specialized method is called. |
Application_InvokeMethod (MethodName as String)
Application_PreInvokeMethod Event |
Called before an applet menu or the InvokeMethod method calls a specialized method. |
Application_PreInvokeMethod (MethodName as String) As Integer
Application_PreNavigate Event |
Called before the Siebel application displays the view where the user navigates. |
Application_PreNavigate (DestViewName As String, DestBusObjName As String)
Application_Start Event |
Called when the Siebel client starts and again when it displays the client interface for the first time. |
Application_Start(commandLine as String)
