Table 118. Summary of Business Component Methods for Siebel VB
ActivateField Method for a Business Component |
Activates a field. |
Dim oBusComp as BusComp oBusComp.ActivateField fieldName as String
ActivateMultipleFields Method for a Business Component |
Activates multiple fields. |
Dim oBusComp as BusComp oBusComp.ActivateMultipleFields oPropSet as PropertySet
Associate Method for a Business Component |
Creates a new many-to-many relationship for the parent object through an association business component. |
Dim oBusComp as BusComp oBusComp.Associate whereIndicator as Integer
BusObject Method for a Business Component |
Returns the name of the business object that the business component references. |
Dim oBusComp as BusComp Dim oBusObject as BusObject Set oBusObject = oBusComp.BusObject
ClearToQuery Method for a Business Component |
Clears the current query but does not clear sort specifications on the business component. |
Dim oBusComp as BusComp oBusComp.ClearToQuery
DeactivateFields Method for a Business Component |
Deactivates the fields that are currently active from the SQL query statement of a business component. |
Dim oBusComp as BusComp oBusComp.DeactivateFields
DeleteRecord Method for a Business Component |
Removes the current record from a business component. |
Dim oBusComp as BusComp oBusComp.DeleteRecord
ExecuteQuery Method for a Business Component |
Returns a set of business component records. |
Dim oBusComp as BusComp oBusComp.ExecuteQuery cursorMode as Integer
ExecuteQuery2 Method for a Business Component |
Returns a set of business component records. Allows you to control the number of records Siebel CRM returns. |
Dim oBusComp as BusComp oBusComp.ExecuteQuery2 cursorMode as Integer, ignoreMaxCursorSize as Integer
FirstRecord Method for a Business Component |
Moves the record pointer to the first record in a business component, making that record the current record. |
Dim oBusComp as BusComp Dim iIsRecord as Integer iIsRecord = oBusComp.FirstRecord
FirstSelected Method for a Business Component |
Makes the first record of the multiple selection in a business component active. |
Dim oBusComp as BusComp Dim iIsMultipleSection as Integer iIsMultipleSelection = oBusComp.FirstSelected
GetAssocBusComp Method for a Business Component |
Returns the name of the association business component. |
Dim oBusComp as BusComp Dim AssocBusComp as BusComp Set AssocBusComp = oBusComp.GetAssocBusComp
GetFieldValue Method for a Business Component |
Returns the value of a field from the current record of a business component. |
Dim oBusComp as BusComp Dim sValue as String sValue = oBusComp.GetFieldValue(FieldName as String)
GetFormattedFieldValue Method for a Business Component |
A field value that is in the same format that the Siebel client uses. |
Dim oBusComp as BusComp Dim sValue as String sValue = oBusComp.GetFormattedFieldValue(FieldName as String)
GetMultipleFieldValues Method for a Business Component |
Returns values for the fields specified in a property set. |
Dim oBusComp as BusComp oBusComp.GetMultipleFieldValues oFields as PropertySet, oValues as PropertySet
GetMVGBusComp Method for a Business Component |
Returns the multivalue group business component associated a business component field. |
Dim oBusComp as BusComp Dim MvgBusComp as BusComp set MvgBusComp = oBusComp.GetMVGBusComp(FieldName as String)
GetNamedSearch Method for a Business Component |
Returns the name of a search specification. |
Dim oBusComp as BusComp Dim sValue as String sValue = oBusComp.GetNamedSearch(SearchName as String)
GetPicklistBusComp Method for a Business Component |
Returns the name of the pick business component that is associated with a field in the current business component. |
Dim oBusComp as BusComp Dim pickBusComp as BusComp Set pickBusComp = oBusComp.GetPicklistBusComp(FieldName as String)
GetSearchExpr Method for a Business Component |
Returns the current search expression that is defined for a business component. |
Dim oBusComp as BusComp Dim sExpr as String sExpr = oBusComp.GetSearchExpr
GetSearchSpec Method for a Business Component |
Returns the search specification for a field. |
Dim oBusComp as BusComp Dim sSpec as String sSpec = oBusComp.GetSearchSpec(FieldName as String)
GetSortSpec Method for a Business Component |
Returns the sort specification for a business component. |
Dim sSortSpec as String sSortSpec = GetSortSpec
GetUserProperty Method for a Business Component |
Returns the value of a user property. |
Dim oBusComp as BusComp Dim sValue as String sValue = oBusComp.GetUserProperty(propertyName as String)
GetViewMode Method for a Business Component |
Returns the current visibility mode for a business component. |
Dim oBusComp as BusComp Dim iMode as Integer iMode = oBusComp.GetViewMode
InvokeMethod Method for a Business Component |
Calls a method. |
Dim oBusComp as BusComp oBusComp.InvokeMethod(methodName as String, methArg1, methArg2, methArgN as String or StringArray)
LastRecord Method for a Business Component |
Moves the record pointer to the last record in a business component. |
Dim oBusComp as BusComp Dim iReturn as Integer iReturn = oBusComp.LastRecord
Name Method for a Business Component |
Returns the name of a business component. |
Dim oBusComp as BusComp Dim sName as String sName = oBusComp.Name
NewRecord Method for a Business Component |
Adds a new record to a business component. |
Dim oBusComp as BusComp oBusComp.NewRecord whereIndicator as Integer
NextRecord Method for a Business Component |
Moves the record pointer to the next record in a business component, making that record the current record. |
Dim oBusComp as BusComp Dim iReturn as Integer iReturn = oBusComp.NextRecord
NextSelected Method for a Business Component |
Makes the next record of the current multiple selection the active record. |
Dim oBusComp as BusComp Dim iReturn as Integer iReturn = oBusComp.NextSelected
ParentBusComp Method for a Business Component |
Returns the name of the parent business component. |
Dim oBusComp as BusComp Dim parentBusComp as BusComp Set parentBusComp = oBusComp.ParentBusComp
Pick Method for a Business Component |
Places the currently chosen record in a pick business component into the appropriate fields of the parent business component. |
Dim oBusComp as BusComp oBusComp.Pick
PreviousRecord Method for a Business Component |
Moves the record pointer to the previous record in a business component. |
Dim oBusComp as BusComp Dim iReturn as Integer iReturn = oBusComp.PreviousRecord
RefineQuery Method for a Business Component |
Refines a query. |
Dim oBusComp as BusComp oBusComp.RefineQuery
SetFieldValue Method for a Business Component |
Sets a new value for a field in the current record of a business component. |
Dim oBusComp as BusComp oBusComp.SetFieldValue FieldName as String, FieldValue as String
SetFormattedFieldValue Method for a Business Component |
Sets the new value to a field for the current record of a business component. |
Dim oBusComp as BusComp oBusComp.SetFormattedFieldValue FieldName as String, FieldValue as String
SetMultipleFieldValues Method for a Business Component |
Sets new values in the fields of the current record of a business component. |
Dim oBusComp as BusComp oBusComp.SetMultipleFieldValues oPropSet as PropertySet
SetNamedSearch Method for a Business Component |
Sets the named search specification on a business component. |
Dim oBusComp as BusComp oBusComp.SetNamedSearch searchName as String, searchSpec as String
SetSearchExpr Method for a Business Component |
Sets a search expression for a business component rather than for each field. |
Dim oBusComp as BusComp oBusComp.SetSearchExpr searchSpec as String
SetSearchSpec Method for a Business Component |
Sets the search specification for a field. |
Dim oBusComp as BusComp oBusComp.SetSearchSpec fieldName as String, searchSpec as String
SetSortSpec Method for a Business Component |
Sets the sort specification for a business component. |
Dim oBusComp as BusComp oBusComp.SetSortSpec sortSpec as String
SetUserProperty Method for a Business Component |
Sets the value of a user property in a business component. |
Dim oBusComp as BusComp oBusComp.SetUserProperty propertyName as String, newValue as String
SetViewMode Method for a Business Component |
Sets the visibility type for a business component. |
Dim oBusComp as BusComp oBusComp.SetViewMode viewMode as Integer
UndoRecord Method for a Business Component |
Reverses any unsaved modifications that Siebel CRM has made on a record. |
Dim oBusComp as BusComp oBusComp.UndoRecord
WriteRecord Method for a Business Component |
Saves to the Siebel database any modifications made to the current record. |
Dim oBusComp as BusComp oBusComp.WriteRecord
