Table 126. Summary of Web Applet Events for Siebel eScript
WebApplet_InvokeMethod Event |
Siebel CRM calls this event after a specialized method on the Web applet runs. |
WebApplet_InvokeMethod (MethodName)
WebApplet_Load Event |
Siebel CRM calls this event immediately after it loads an applet. |
WebApplet_Load
WebApplet_PreCanInvokeMethod Event |
Called before Siebel CRM calls the PreInvokeMethod event, allowing you to determine if the user possesses the authority to call the applet method. |
WebApplet_PreCanInvokeMethod (MethodName, &CanInvoke)
WebApplet_PreInvokeMethod Event |
Siebel CRM calls this event before it calls a specialized method for the Web applet or a custom method that it calls through the oWebApplet object of the InvokeMethod method. |
WebApplet_PreInvokeMethod (MethodName)
WebApplet_ShowControl Event |
Allows a script to modify the HTML that the Siebel Web Engine creates when it renders a control on a Web page in a Siebel application that runs in standard interactivity mode. |
WebApplet_ShowControl (controlName, property, mode, &HTML)
WebApplet_ShowListColumn Event |
Allows a script to modify the HTML that the Siebel Web Engine creates when it renders a list column on a Web page in a Siebel application that runs in standard interactivity mode. |
WebApplet_ShowListColumn (columnName, property, mode, &HTML)
