Table 127. Summary of Application Methods for Siebel eScript
ActiveBusObject Method for an Application |
Returns the name of the business object that the active view references. |
var busObject; busObject = TheApplication().ActiveBusObject();
ActiveViewName Method for an Application |
Returns the name of the active view. |
var sView; sView = TheApplication().ActiveViewName();
CurrencyCode Method for an Application |
Returns the currency code that is associated with the division of the user position. |
var sCur; sCur = TheApplication().CurrencyCode();
GetBusObject Method for an Application |
Creates a new instance of a business object. |
var myBusObject; myBusObject = TheApplication().GetBusObject( BusObjectName);
Returns the name of the Siebel application. |
var name; name = TheApplication().Name();
GetService Method for an Application |
Locates a business service. If this business service is not already running, then Siebel CRM starts it. |
var Service; Service = TheApplication().GetService (serviceName);
GetSharedGlobal Method for an Application |
Returns the shared global variables. |
var sName; sName = TheApplication().GetSharedGlobal (varName);
GotoView Method for an Application |
Activates a view. |
TheApplication().GotoView( viewName[, BusinessObject]);
InvokeMethod Method for an Application |
Calls a method. |
TheApplication().InvokeMethod( methodName, methodArg1, methodArg2,..., methodArgn);
LoginId Method for an Application |
Returns the login ID of the user who started the Siebel application. |
var sID; sID = TheApplication().LoginId();
LoginName Method for an Application |
Returns the login name of the user who started Oracle's Siebel application. |
var sUser; sUser = TheApplication().LoginName();
NewPropertySet Method for an Application |
Creates a new property set. |
var oPropSet; oPropSet = TheApplication().NewPropertySet();
PositionId Method for an Application |
Returns the position ID of the user position. |
var sRow; sRow = TheApplication().PositionId();
PositionName Method for an Application |
Returns the name of the current user position. |
var sPosition; sPosition = TheApplication().PositionName();
RaiseError Method for an Application |
Sends a scripting error message to the browser. To determine the error text, Siebel CRM uses a key to look up the current language. |
var keyVal; var arg1 ...; TheApplication().RaiseError(keyVal, arg1, ...);
RaiseErrorText Method for an Application |
Sends a scripting error message to the browser. |
var message; TheApplication().RaiseErrorText (message);
SetPositionId Method for an Application |
Sets the active position to a position ID. |
var success; success = TheApplication().SetPositionId (posId);
SetPositionName Method for an Application |
Sets the active position to a position name. |
var success; success = TheApplication().SetPositionName (posName);
SetProfileAttr Method for an Application |
Personalization uses this method to set a value for an attribute in a user profile. |
TheApplication().SetProfileAttr (name, value);
SetSharedGlobal Method for an Application |
Sets a shared global variable. |
TheApplication().SetSharedGlobal (varName, value);
Trace Method for an Application |
Appends a message to the trace file. |
TheApplication().Trace(message);
TraceOff Method for an Application |
Turns off tracing. |
TheApplication().TraceOff();
TraceOn Method for an Application |
Turns on tracing. |
TheApplication().TraceOn(filename, type, selection);
