Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > About Dynamic Transform >
Target Promotions Applet
While performing a dynamic transform, the Target Promotions applet is displayed. The applet lists the definition of the target promotion. Table 8 describes some of the columns in the Target Promotions applet.
Table 8. Target Promotions Applet Descriptions
Line # |
The line item number. |
Product |
The promotion header or promotion component definition when the line item is non aggregated product. |
Aggregate Type |
The aggregate type when the line item is an aggregated product. |
Aggregate Name |
The aggregate name when the line item is an aggregated product. |
Description |
A description of the product or aggregated product. |
Min |
The minimum cardinality value. |
Max |
The maximum cardinality value. |
Cardinality |
Indicates whether the line item adheres to the cardinality rules:
- An X is displayed when the cardinality rules are not respected.
- A check mark is displayed when the cardinality rules are respected.
Quantity |
Quantity of the asset. |
